Old 05-05-2014, 10:47 AM   #169
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by switz View Post
Since the production is sold out six months, why would Airstream decrease their profit margins by installing quality skylights? Wait until you see inside the electric outlets. They make the cheapest units at a local discount store look like Military Spec.
We installed the Maxim frosted white over the bath area and a bronze unit in the living room.
Someone in your family must share my wife's paranoia about people climbing trees to look into the trailer through the skylights. I finally convinced her that the pull closed horizontal shades would discourage all but the most determined squirrels. I am one who enjoys the maximum natural light, so we went with the triple clear on both skylights.
There are a lot of cheap components in an Airstream, considering the abuse it takes while being towed. All the plastic latches and other hardware on drawers and doors come to mind. I would not buy those for my home and it doesn't even get dragged down the road.
Ken
Old 05-05-2014, 11:17 PM   #170
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Ken
We like the clear/frosted/clear on both Maxims. No matter where the light is coming from, sunrise, sunset or high noon we get max light in the trailer with no glare. The temp transfer insulation quality is amazing, the trailer stays much cooler/warmer as required.
SuperTrouper is offline   Reply With Quote
Old 05-06-2014, 04:19 AM   #171
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The frosted white is the the Maxim best heat gain blocker per their specifications and also generates the most diffused light for in the bathroom area which is pretty dark with only one light fixture.
Old 05-06-2014, 05:53 AM   #172
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
One thing to add to this five-year old post is that just a thought- air conditioners were designed for humid climates. In a dry climate, if you raise the humidity in a space it should help the ac to work better.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-06-2014, 10:38 AM   #173
Ag&Au's Avatar
My problem is probably that I spent the first 50 years of my life in western Washington. Now that I have escaped, I try to get the maximum light and/or sun available at all times. However I doubt that I will ever catch up.
Ken
Old 05-12-2014, 07:35 AM   #174
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I finally took some time and did the the skylight project over the weekend.
I had the typical issues like everyone else - cracked, leaky skylight - a project way over due.
The old skylight. I caulked the screwheads about two years ago but I knew I was on borrowed time with this band-aid fix. When I removed the caulk the flange was cracked in several places.
Cracked flange
old caulking on skylight curb
When fitting up the new skylight I noticed it would not fit properly down onto the curb. Upon further inspection I noticed the welds on the curb and skylight welds were too thick to allow it to fit into place.
I used a metal file and metal burr on a Dremel to reshape the welds just enough for the skylight to fully slide down onto the curb
Here is the finished project.
Curb to skylight flange - Trempro (vulkem) caulking
Curb to roof caulking - Dyco C10 Flow Seal
Screws - 3/4" x #10 stainless steel screws with a dab of vulkem - inside and out.
The original skylight is a piece of junk - even when it was new. This is a necessary up-grade for any trailer with the original skylight.
Thanks again to Bambi-Bandit for doing the original legwork for this upgrade.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-19-2014, 03:55 PM   #175
Westfalia's Avatar
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Trying to gauge the best color combo before I order. Also I haven't seen this information in the is thread, so I'd like to provide the info that I have from Maxim regarding light and solar transmission [outer-middle-inner]:
Clear-Bronze-Clear: 25% light, 60% solar
Clear-Grey-Clear: 43% Light, 60% Solar
Bronze-Bronze-Clear: 7% Light, 36% Solar
Clear-Grey-Grey: 7% Light, 36 % Solar
Maxim says Bronze-Bronze and Grey-Grey are both too dark to see out of when not in direct sunlight. I don't want to overly darken the trailer but I want to cut the heat load as much as I can I'm leaning towards CGC after my discussion with them strictly due light quality.
Any other regrets?
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 05-19-2014, 04:29 PM   #176
dznf0g's Avatar
Oswego , Illinois
I am happy with CBC. I like the way the bronzed light plays off my particular interior color scheme.
-Rich-
Old 05-19-2014, 04:41 PM   #177
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I like clear as you can see the stars.....
Old 05-19-2014, 05:30 PM   #178
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We have Bronze / Clear / Clear, seems to work fine for us, not too dark, not to bright, just right ! Would chose the same combination again.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-19-2014, 06:02 PM   #179
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Brian.
Wingeezer,
Is the bronze layer the outermost one?
Thanks,,,
tinbender is offline   Reply With Quote
Old 05-19-2014, 08:09 PM   #180
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I got clear/clear/clear. Happy so far.
One of my skylights has a big blob of pine sap on. How should I clean that? Mild detergent and water will not touch it.
Alan
Old 05-19-2014, 08:20 PM   #181
Wingeezer's Avatar
2005 30' Classic
Alan,
Couple of thoughts,
- let it soak in WD-40?
- goo gone?
- automotive tar and sap remover?
I don't think any of these things would harm the plastic, but might be worth contacting Maxim to get their advice.
I would use only soft cloths as I think even paper shop towels might cause abrasion. Not sure, but better safe than sorry!
Brian.
2005 Classic 30'
Old 05-19-2014, 08:21 PM   #182
Wingeezer's Avatar
2005 30' Classic
Originally Posted by tinbender View Post
Wingeezer,
Thanks,,,
Yes, that's right. Don't know if the order would make much difference though. perhaps slightly less heat transmission with the bronze outermost?
Brian.
2005 Classic 30'
oem skylights, replace
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 08:49 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 03:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 08:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 09:32 AM
