Old 02-05-2012, 09:27 AM   #127
2004 16' International CCD
Orem , Utah
3m Marine 5200 sets up like brick
This is same product you use on boats in transom area. Say you drill rear for new fishfinder. Standard procedure is to either squirt stuff in holes or slather bolt threads before installing. How come airstream would half arse and just slather on top bolt head lol. Use 5200 when you never plan on taking appart again. 4200 is lighter duty but still works fine and is easier to remove. Is there another product in clear I can use on all bolt threads thinking trying parabond clear. Wow just remembered my boat dealer has Lifeseal in clear similar to 3m
starcraft is offline   Reply With Quote
Old 02-08-2012, 10:12 AM   #128
Flying Gypsies's Avatar
2006 31' Classic
Archer , Florida
You will love the BBC- sooooooo much better than original- keep us posted
Flying Gypsies is offline   Reply With Quote
Old 02-08-2012, 10:14 AM   #129
2006 31' Classic
Archer , Florida
Darn iphone- i actually like the BCC the best- more natural light
Old 03-10-2012, 07:00 PM   #130
2005 28' Safari
Finally Done!
Thanks Kevin! Such a superior product! After poking around, I found that both the skylight and vent fan were leaking, so both needed to go. They want $150 for the stock skylight... it's a true pos. You'd think, if buying one new, that they put some quality components on such a high $$ trailer.
I ordered the 25% light passage version and are happy with that to get more light inside, but will need to insulate or put an outside cover on during the summer.
Anybody know of an external cover available like the A/C covers?
Here's the materials and picture progression... Getting the old stuff off took the most time!
1) 3M speciality adheasive remover
2) Sikaflex 221 for the screw holes and gasket on the curb for the skylight
3) 3M Marine Adhesive/Sealant Fast Cure 4000 UV for the curb seal
4) Crown Bolt #10 x 1" self tapping metal fasteners (1 1/4s wern't necessary)
5) EDPM washers from the Palram wood screws
And a few pictures:
ID:	153041   Click image for larger version
ID:	153043   Click image for larger version
ID:	153045   Click image for larger version
PaulAir is offline   Reply With Quote
Old 04-19-2012, 05:16 PM   #131
cammur's Avatar
Roseville , California
In understanding the Maxim PDF in Kevin's Post 11, it helps to realize it is only showing what you get from Maxim.
The wide flat horizontal pieces shown left and right go all the way around the skylight, and rest via gravity on the trailer skylight curb. You attach it to the curb with a sealant (Airstream is now using AdSeal rather than Sikaflex). In addition, there are three screw holes in each of the four sides of the skylight. You need to drill matching holes in the curb. I used #10 x 1" SS Hex machine screws from Home Depot to attach the skylight securely to the sides of the curb.
I had only two real problems with Kevin's very fine procedure. On my 25' Safari the air conditioner sits too close to the curb to allow me to drill the needed curb holes on that one side. I'm counting on the other nine screws being sufficient, combined with the sealant on all four sides. It really feels quite solid and I'm not concerned.
Oh, the other problem? While working on the skylight I noticed the caulking was separating on the nearby Fantastic Fan. I removed the caulk on the offending side and found numerous very rusty half-inch #10 wood screws securing the frame of the fan box to the trailer. The frame is plastic and also had several cracks radiating from the screw holes. One corner was broken off and missing, obviously missing in the original factory installation. Another fine quality job from Airstream.
(I'm sorry this post is appearing so far away from where I intended. Don't know how to correct that.)
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 04-19-2012, 07:53 PM   #132
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I was up on the rooftop myself the other day and noticed that the vulkem I used to seal my fantastic fan was also cracking that I out on there a year ago. Does vulkem not have good uv properties?
ddstech is offline   Reply With Quote
Old 04-20-2012, 08:18 AM   #133
2005 28' Safari
I'd suggest getting a new fan frame and replace the damaged one. Fantastic should have provided stainless hardware. The crack is probably the result of screwing it down in the corners and not leaving a gap. My frame has around a 3/16" gap at the corners, but flush in the center. The gaps are filled and supported by butal tape and caulk.
I recommend:
The stuff is made for boats, so I think it's appropriate for our land barges!
Old 07-01-2012, 07:38 AM   #134
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
Going thru a minefield? Follow someone.
The saying about traversing a minefield was one my father taught me. Sage advise I followed when faced with a skylight leak in our 07 Safari. Let me begin by thanking Bambi Bandit for marking the trail thru the minefield so clearly. I just completed installation of my new Maxim skylight, and wanted to share some observations.
Followed Bandit's instructions and they worked flawlessly. Only new twist was I found using a single edge razor paint removal tool to help "cut" thru the silicone easily. And I used a plastic putty knife to remove the silicone on the painted roof surface which worked very well and did not scratch the paint.
Thanks also for guiding me to Maxim. Great folks to work with (David and Liz) and the quality of the skylight is outstanding. Price up a bit from Bandit's experience, mine ran about $250 delivered, but well worth it.
I also ended up using AdSeal silicone adhesive which Airstream now uses and sells through the store. It is a humidity cure sealant, which Maxim recommended vs a solvent cure (which can attack the skylight components so I'm told by David at Maxim).
I will share that once I pealed the silicone from screws securing the factory skylight I was stunned at the damage done to the dome during installation. The over-torqued screws at three corners had completely destroyed the integrity of the dome. The fact it did not leak worse than it did is a testament to the silicone Airstream was using at the time. I will let the photos speak for the workmanship.
The last photo shows the new Maxim skylight installed.
Again, tip of the old hat to Bandit for forging the trail.
ID:	162162   Click image for larger version
ID:	162164   Click image for larger version
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 07-01-2012, 09:55 AM   #135
Steelegood's Avatar
2005 31' Classic
Cleveland , Tennessee
WOW! That's about all I can say. What an outstanding job you did thanks for the pictures and tips!
I know you think you understand what you though I said, but I'm not sure that what you heard is what I actually meant!
"If you don't know where you are going, any road will take you there." Lewis Carroll
AIR #38011
TAC TN-4
NOVA
Steelegood is offline   Reply With Quote
Old 07-02-2012, 05:22 AM   #136
Alumitater's Avatar
2007 25' Safari
walking thru a minefield
You are most welcome. Again, Bandit did all the hard trailblazing. I just followed.
Tom and Robin
Old 03-19-2013, 02:04 PM   #137
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
I just emailed for a quote and the current prices for the 22.25 x 22.25 is $252 and the 17.25 x 25.25 is $208, turn around time is 12 days.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 03-20-2013, 06:21 AM   #138
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Alumitater...... I'm planning to order a Maxim for my 2007 Safari 25' FB. What size skylight did you order for your 2007 Safari 25' FB ?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 03-21-2013, 05:35 AM   #139
Alumitater's Avatar
2007 25' Safari
Maxim Skylight
Good morning.
I ordered a 22.25" X 22.25", which was their part number 2323DCMBBCBA, curb mount, bronze/bronze domes, clear flat panel, bronze anodized finish. As I am recalling, they only offered two sizes for Airstream trailers, one which was square and one rectangular, but I may be incorrect on that (if it was more than yesterday, memory fades quickly....age thing I guess).
The folks at Maxim were great to work with and the product is outstanding.
We have been really pleased with our choice. I no longer have to use the sliding shade to protect from heat gain in the trailer, and really enjoy the light it adds. The bronze domes were a good choice for heat protection for us here on the Gulf Coast, and we have the Stratus color scheme (which is basically tans and browns) so the color of light it emits fits nicely.
Holler back if I may be of any further assistance. You will be most pleased with your efforts and replacement skylight.
Tom and Robin
Old 03-23-2013, 11:41 AM   #140
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Vinnie is here to put in my new Maxims yea!
SuperTrouper is offline   Reply With Quote
oem skylights, replace
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 02:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 07:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 08:32 AM
