Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 07-07-2009, 12:18 PM   #1
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Step by Step: Replacing OEM skylights with new Custom Maxim Skylights
Problem 1: Original OEM skylights, leaking due to over torqued screws cracking the skylight during airstream manufacturing - replaced in June 2008 at JC... again, over torqued and cracked.....and leaking!
Problem 2: Hot as Hll in Texas. Dometic 15K barely keeping up (with issues of it's own) and direct sunlight making skylight into magnifying glass in trailer.
Problem 3: Storms in Texas able to drop hail size of various sporting goods balls from marble to golf to baseball...Need to ensure best impact resistance to minimize any hail intrusion.
Solution: Custom skylights made to fit current aluminum curb. Maxim skylights. Options of # of Domes and tint (light passthru) and frame (anodized or non), built to Miami Dade/Florida and Texas Coastal Hurricane wind and impact resistant skylights.
Specs on the the "hurricane resistant" model as attached:
File Type: pdf Dade Curb Mount Approval Detail Model (1).pdf (273.7 KB, 2162 views)
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 07-07-2009, 12:26 PM   #2
Images: 12
Step 1 - remove skylight screws and caulk
(I have 2 skylights on my 27FB international. This thread will show the skylight replacement midship over the bathroom / hall area)
Peel back the caulk on the skylight screws.
Note the cracking on the caulk that is 1 year old from JC? This is what it looks like with the first 6 months in covered storage, followed by 6 months in the elements.
Also note the water on the screw head from the previous rain.
Can we see the large cracks from the over torqued screws?
The silver radiant barier is tucked in the skylight openeing from inside the trailer.
Name:	P6213490 (Large).JPG
ID:	83560   Click image for larger version
Name:	P6213492 (Large).JPG
Name:	P6213493 (Large).JPG
ID:	83562   Click image for larger version
Name:	P6213495 (Large).JPG
Name:	P6213498 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 12:29 PM   #3
Images: 12
Step 2 - Pry off with stiff putty knife
Gently work a stiff putty knife under a corner and pry... the rest will follow...
Note I left the radiant barrier in place to keep the AC in best I could during this process.
Name:	P6213499 (Large).JPG
ID:	83565   Click image for larger version
Name:	P6213501 (Large).JPG
Name:	P6213502 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 12:32 PM   #4
Images: 12
Step 3 - Scrape the caul off the top of the curb
Take stiff putty knife and scrape the curb. Note that the welds on the corner are not ground down. Existing screw holes will be rough to work with the knife. Wire Brush will help.
Note: newer trailers with skylights installed with double sided tape adhesive versus screws should have welds ground down already.
Name:	P6213506 (Large).JPG
ID:	83568   Click image for larger version
Name:	P6213508 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 12:36 PM   #5
Images: 12
Step 4 - Measure your crub
Measure your curb and call / e-mail Maxim with your size. Note to get the outer curb size as well as the curb height.
Note that I measured height with the existing sealant / caulk in place since new sealant/caulk would take approximately the same height.
Name:	P6213511 (Large).JPG
ID:	83570   Click image for larger version
Name:	P6213512 (Large).JPG
Name:	P6213513 (Large).JPG
ID:	83572   Click image for larger version
Name:	P6213514 (Large).JPG
Name:	P6213522 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 12:41 PM   #6
Images: 12
Step 5 - Strip the old sealant/caulk off the roof and curb
This is the most time consuming part. Take a stiff putty knife and scrape, scrape, scrape... Again, Wire brush will help.
After you have scraped and brushed most of what you can (even with your fingernails) use acetone to clean down to the metal.
Note that you DO NOT want to remove the caulk under the existing curb that is RIVETED down. Just get up as close to it as possible. The existing seal there will be covered with new caulk/sealant.
Name:	P6213531 (Large).JPG
ID:	83575   Click image for larger version
Name:	P6213545 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 12:46 PM   #7
Images: 12
Step 6 - New caulk/sealant around curb
Take your favorite caulk/sealant and use like its going out of style. I used 2 tubes of 3M Marine 5200 and spread it like icing on a cake. The curb will NEVER leak now... (Never say never - I'm sure I just jinxed myself now)
***Use Gloves for this process, otherwise all your tools, ladder, and anything you touch will be a mess. Keep spares in your pocket to minimize runs up and down the ladder....****
Name:	P6213550 (Large).JPG
ID:	83577   Click image for larger version
Name:	P6213552 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 12:47 PM   #8
Stephen Mick's Avatar
2006 28' International CCD
Kevin,
You're got to stop posting stuff like this. It really make me want to get the tools out and rip into the top of my trailer!
--SM
Stephen Mick is offline   Reply With Quote
Old 07-07-2009, 12:59 PM   #9
Images: 12
Step 7 - Attach new skylight
You have 2 choices here. First, hopefully you will have gotten a new skylight from airstream or your dealer if under warranty and you can now caulk on and carefully screw the OEM skylight on for temporary use while you wait for Maxim to make your new custom skylights, OR, you already know your measurements from previous walks on the roof and have the new skylight from Maxim in hand.
On the skylight over the galley/kitchen, I was able to measure without removing the skylight. Others may have so much caulk on the curb that will require removal of the skylight to get an accurate measurement, as was the case for this skylight here.
I will skip showing the install of the OEM skylight for temporary use as most know how to do that properly without over torquing the screws...
Dry fit your new skylight on the curb. Note that the new Maxim skylights are built with 1/4 in tolerance on each side. This is a nice SNUG fit as compared to OEM.
Using a marker or scratch awl, mark areas where the new skylight will screw in. Note that the new Maxim skylights screw in horizontally on the curb.
Once you have figured out where your new skylight will "sit", remove it and liberally Apply your favorite caulk/adhesive to the top of the curb (not shown). Also apply large blobs of caulk where you marked the screw holes will be on the curb, since you will not be able to access this area once they skylight is on.
Go ahead and glob over the screw head as well... Even though we are using fasteners with neoprene gaskets that seal, you can never be sure...
Sorry for the lack of photos here - it was getting darn hot on that roof and I started to hurry!
Name:	P7023571 (Large).JPG
ID:	83582   Click image for larger version
Name:	P7023572 (Large).JPG
Name:	P7023573 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 01:23 PM   #10
Images: 12
Fasteners I used
Since we are going in horizontally and thru caulk blindly into the curb, a self tapping fastener is the ideal. Drilling would be a pain...
I went to home depot and purchased Crown Bolt #10 x 1 1/4 inch self tapping metal fasteners, as well as palram wood screws (metal roofing section) with and EDPM washers.
I then took the washers off the Palram wood screws and put them on the crown bolts. A self tapping fastener with EDPM washer. No drill needed now!!!
Product Information Error Page
Woodtite Woodtite 1 In. - 50 Pc. - 92522 at The Home Depot
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 01:31 PM   #11
Images: 12
Finished Product
I opted for a double dome, both bronze) with 7% light transmission, as well as a clear flat on the "inside". total of (3) layers of polycarbonate for protection and better insulation. I also selected the anodized aluminum frame.
Here are the specs of my skylights as made by Maxim, as well as views of the completed install.
Total cost of skylights was ~$300 (~$150 each) 6 tubes of caulk were ~$12 each (on sale at West Marine) and fasteners from Home depot were ~$14.
The skylight lets in a bronze light, which I love as it complements the dark "espresso" colored laminate of the International CCD.
Name:	P7023576 (Large).JPG
ID:	83592   Click image for larger version
Name:	P7023578 (Large).JPG
Name:	P7023579 (Large).JPG
File Type: pdf Kevin Li Dade Curb Mount Approval Detail Model (1).pdf (264.9 KB, 873 views)
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-07-2009, 03:40 PM   #12
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Cool Kevin (pardon the pun!). I might just use Maxium to replace my '64 Solordome instead of the fiberglass replacements. I wonder if my stock openers would rivet on the frame too?
Marc
Old 08-19-2009, 04:33 PM   #13
Astroboy's Avatar
2007 28' International CCD
West Hollywood , California
Wow.
Wow. Wow. Wow.
Wow x 100, & more.
I've been staring up my skylight (cracked and duct-taped) for several weeks and pondering about its replacement for something better than an OEM plastic.
Fortunately for me, you beat me to it.
Thank you for the write-up and photos.
Astroboy is offline   Reply With Quote
Old 08-29-2009, 07:40 AM   #14
Rockville Centre , New York
great thing thank u
Josie28 is offline   Reply With Quote
Old 09-27-2009, 03:18 PM   #15
Smile Good Job, Kevin
I have 65 tradewind and might put in permanenet instead of raisable skylight, but you give me good hints. Tks
bdlwet is offline   Reply With Quote
Old 09-28-2009, 01:54 PM   #16
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
New Maxim enroute
After reading this thread last week as we've been solving our own water leak issues, decided to "permanently" replace our two skylights.
After a couple phone calls with David Thornton at Maxim, I placed the order and the two skylights are expected to arrive this Wednesday.
Looking forward to installing these.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 09-28-2009, 04:15 PM   #17
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Delivery time?
Nice post, Kevin.
How long does it take to get delivery from the day you order them?
Thanks.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 09-28-2009, 04:19 PM   #18
dpandorf's Avatar
2000 34' Limited
I ordered mine last Wednesday and they shipped today and delivery is this Wednesday. Shipping is not cheap as they will not use FedEx ground. You'll need a commercial address to ship to. I'm using a friends contractor's office which is just up the road from where I live.
Duane Pandorf
Blog | Google+
Old 09-28-2009, 09:45 PM   #19
dpandorf's Avatar
2000 34' Limited
Weather forecast for new Maxim Sunlight install
Its been raining cats and dogs that last couple weeks here in the mountains. My new skylights are expected to arrive on Wednesday and I plan on installing them on Thursday.
Brevard, NC weather forecast
Then we hit the road for 2 months once that's complete.
Duane Pandorf
Blog | Google+
Old 10-24-2009, 08:27 PM   #20
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Replacing OEM skylights with Maxim Skylights
Bambi Bandit... Want to thank you for your detailed instruction on mounting the Maxim skylight. In your pictures of the installed skylight I can see a number of bronze colored screws on the top of the frame as well a some on the sides of the frame that were not caulked. I see that you caulked all of the screws you installed to mount the skylight down to the sides of the trailer installed frame but did not caulk the others. Just wanted to know why you did not caulk the other screws.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
oem skylights, replace
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 02:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 07:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 08:32 AM
