Old 02-10-2006, 11:15 AM   #1
solar domes
This subject may have been covered in the past but, rather than sorting thru all that I thought I would broach the subject anew. I'm the proud owner of a 1977 Excella 500. Everything works, including the original braking system, however, there is one problem. The solar domes. My Airstream has three and they are all cracked and leaking. Are replacements available or do I need to replace the whole assembly, fans and all? Or, can I just purchase a flat piece of acrylic and replace. There's an aluminum frame around the dome and it looks like the plastic is flat but it's hard to tell with all the discoloration and silicone caulk on them. Help!
mjbord is offline   Reply With Quote
Old 02-10-2006, 11:58 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
you will be hard pressed to find ones as nice as the aluminum ones you have. not to mention the difficulty you would have adapting new ones to your opening levers.
replacing the acrylic sections and new seals would be the least expensive and easiest to do.
john
you call them ferrets, i call them weasels.
Old 02-10-2006, 05:38 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
My '77 vents had cracked years before I bought the trailer. The PO had someone rivet a sheet of aluminum, radiused on the corners, where the dome had been before on all 3 vents. It worked fine. I had Vista View windows so I never though the trailer was dark.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-11-2006, 05:13 AM   #4
Thumbs up sloar domes
I think rather than using acrylic again I'll try to find some UV resistant Lexan. I believe that it will last alot longer than acrylic. Thanks for the input!
Old 02-27-2006, 01:43 PM   #5
As an update, you can't believe the amount of silicon caulk that was on my solar domes. I would guess the P.O. used at least 10 tubes to stop the leaks rather than doing it right. It took longer to get the old stuff off than it did to do it properly. I guess some folks are just lazy or just looking for a quick fix.
Old 03-08-2006, 06:56 PM   #6
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
For your solardoms you can get new ones from Inland Rv , I put new ones on my 1969 sovereign 31' trailer.
They will have them in stock, and could ship them directly to your home!!!!!
Check there website !!!
william Haym is offline   Reply With Quote
Old 03-08-2006, 08:36 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
It's amazing how many people use silicone to seal leaks on RV's! Everytime I get called on an exterior leak, the first thing I ask is 'did you try silicone?' When they answer yes, I say 'You should have called me first 'cause now it will be double! First to remove what you did and then do it properly. As my labor rate says:
Labor rate:.......................................$50/hour
If you watch.....................................$75/hour
If you help.......................................$100/hour
If you worked on it first......................$150/hour
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
