| Small box fans
I have a couple 3 1/2-4" 12 volt box fan sitting around and was wondering if I mounted one or two of them on an aluminum sheet then placed this sheet over a vent opening, would this keep the interior any cooler while the unit sat around not being used? I thought about wiring this into a 5 watt solar panel so that the fans run during the heat of the day then taper off as it gets dark. Any ideas? Craig
__________________ Craig AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
