Old 09-29-2013, 05:02 PM   #1
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Skylights
We were told that your skylights are starting to show cracks and that they might need to be replaced soon. How difficult is it to replace the skylights? I have two on our 2006 Classic. Any idea of how much approximately they cost? Thanks
kswelsh is offline   Reply With Quote
Old 09-29-2013, 05:12 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
There are threads on here about skylights already. Suggest you do a search.
Al - K4GLU is offline   Reply With Quote
Old 09-29-2013, 05:25 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Difficult....not really. Hardest part, removing all the carefully applied factory caulking.
Everyone has a preference as far as replacements, I used one from Inland RV, much better quality than the one used by the Factory.
Others prefer the bullet proof options.
You'll probably find that yours is cracked because the person responsible for it's installation couldn't control his screwdriver!
Ours was cracked at every screw hole. Same with the Fantastic Vent hinges and black tank vent.
I would advise a trip to the AS roof and inspect first-hand.
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-29-2013, 06:04 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Search Maxim
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2013, 08:02 PM   #5
dznf0g's Avatar
Oswego , Illinois
Very happy with my Maxims. About $400 and change as I recall, for a pair.
-Rich-
Old 09-29-2013, 08:41 PM   #6
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
One of mine 'blew off' during my maiden voyage, so I replaced both with OEM available from OODM (also available from Inland RV or the mothership). I was really disappointed with how cheap they seem to be, but due to lack of funds, installed them anyway. I'll go with the Maxim's next time. OEM should not be used in the Southwest because all the exterior plastic needs to be periodically replaced.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 09-29-2013, 08:47 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've had to replace both skylights on our trailer. The first was under warranty and the second was on my nickel. The dealer said that the one done warranty had been cracked by over tightening at the factory. The other one went from UV and I think with labor cost me about $200+ installed. Those failures occurred within the first 3 years of ownership. With the trailer now stored indoors, UV exposure is limited to trips only which should extend the life of the skylights.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-29-2013, 08:55 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
A whole Texas summer with Maxims... No leaks, crystal clear and with 3 layers, hurricane resistant.
Channing
WBCCI# 30676
Old 09-30-2013, 05:04 AM   #9
Thumbs up
FWIW
This one referenced in my previous post is not an OEM replacement, much better quality.
303 UV protectant will help with all things UV. I use it on all roof plastic, tires window seals, boat vinyl seats/trim etc.
PFC
"Tahawus"
RLC
Old 09-30-2013, 09:14 AM   #10
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
The link below shows how I did, step-by-step. I started at 8 am and was done by Noon. Easy:: Skylight Replacement | Cabin at Dogwood Lane
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
