Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 08-19-2009, 01:40 PM   #1
Profile:  2004 28' Classic
El Dorado , California
skylight replacement
I have a 2004 28 ft. Classic trailer and have noticed leaks around the areas of the two skylights. I pulled off the skylights and cleaned and replaced them with fender washers and new sealer. However they will have to be replaced. Are there any lexan or polycarbonate skylights out there that will fit our trailers --if so who makes them? The originals just do not hold up.
lrwarren is offline   Reply With Quote
Old 08-19-2009, 02:17 PM   #2
Profile:  2008 16' Safari
Destrehan , Louisiana
Try this site:
RV Skylights
dlb435 is offline   Reply With Quote
Old 08-19-2009, 03:00 PM   #3
Astroboy's Avatar
Profile:  2007 28' International CCD
West Hollywood , California
InlandRV carries ones with thermobarrier for Airstreams. They're thicker, more durable and long-lasting than originals.
Astroboy is offline   Reply With Quote
Old 08-19-2009, 04:20 PM   #4
Profile:  2004 30' Classic Slideout
. , Kentucky
I replace the skylights on my 2004 Classic this spring with a kit from Out of Doors Mart. These are the same skylights the factory uses with a little different installation method. Out of Doors Mart includes a set of aluminum moulding to hold the edges of the skylight down. The installation was fairly simple and seems to be working great. If you check out their web site under the "Airstream Projects" Tab you will see a step by step installation of their kit. I did look at some of the thicker skylights and think they would work good also but felt they defeated the purpose of the skylight by blocking to much light. What ever route you go be sure to drill the holes in the skylight a litter bigger than the mounting screws to allow some movement without putting strain on the plastic skylignt.
Best of luck with your project
fltlevel510 is offline   Reply With Quote
Old 08-19-2009, 04:50 PM   #5
Astroboy's Avatar
Originally Posted by fltlevel510 View Post
What ever route you go be sure to drill the holes in the skylight a litter bigger than the mounting screws to allow some movement without putting strain on the plastic skylignt...
I need to replace mine too, and about to pull the trigger ordering...
Thanks.
Old 08-19-2009, 05:38 PM   #6
Astroboy's Avatar
Just happened to come upon this thread, more than worth your time checking it out...
Step by Step: Replacing OEM skylights with new Custom Maxim Skylights
Skylight inspection Dan4odm Roof Vents, Skylights & Fans 7 06-04-2009 10:05 PM
Skylight Dilemma moosetags General Interior Topics 6 04-25-2008 12:39 PM
Skylight plastic replacement. reece1107 Roof Vents, Skylights & Fans 7 02-20-2006 01:51 PM
skylight fix-up MariaRita Windows & Screens 7 07-21-2005 01:27 PM
Skylight Insight nevisstudio Roof Vents, Skylights & Fans 2 08-28-2004 10:32 AM
