Old 02-19-2006, 02:36 PM   #1
1972 31' Sovereign
mountain view , California
Skylight plastic replacement.
What kind of plastic top will replace the originals? I am not going to spend $70 for the "original". What other types are acceptable?
reece1107 is offline   Reply With Quote
Old 02-19-2006, 02:43 PM   #2
simonhanbury's Avatar
Images: 62
what is wrong with your vents that have you wanting to replace them? Mine were fine other than the horrible looking plastic "windows"-I took mine apart and replaced the yellowed brittle plastic covers with new lucite panels. Now I can see the moon shine through at night and I get lots of light from above! I should also mention that I removed the whole plastic interior fitting too! Not sure if this idea helps but I thought I try!
Simon
simonhanbury is offline   Reply With Quote
Old 02-19-2006, 04:30 PM   #3
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Just bought a 58 Overlander International. Whatever was in the front ceiling is gone. It's not square by retangular and missing. There is a board covering the hole with caulk all around it. What was there and can it be replaced?
juel is offline   Reply With Quote
Old 02-19-2006, 05:22 PM   #4
Ohanastar's Avatar
1964 24' Tradewind
Cardiff , California
Skylight question?
Hi Juel!
I think the hole in the ceiling of your Airstream is a missing Astrodome (sometimes spelled Astradome) skylight. Both Vintage Trailer Supply (www.vintagetrailersupply.com $159.95) and Inland RV (www.inlandrv.com $137.95) carry the size I believe you need. I ordered a replacement from Vintage Trailer Supply and am OH SO HAPPY with it. (My other was crumbling from age.) Vintage Trailer Supply has some installation tips for you online, as well.
If you are interested in viewing some other Airstreams, your make and year, you can search www.vintageairstream.com for photos in their archives.
Hope this helps!
Ohanastar is offline   Reply With Quote
Old 02-19-2006, 08:05 PM   #5
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Thanks for that information. The vintage trailer supply says they don't carry the hardware for this thing. I'm not sure any of that is still in the trailer. Guess I will know more when I get her home. Maybe next week if they can get the duplicate title from California. Oklahoma won't take a Bill of Sale to register the trailer. Want to get her home and begin inventory on what needs to be done.
Old 02-20-2006, 12:01 AM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Missing dome
Judy, Hope the only thing missing on the "new" baby is the plastic dome itself. From what I understand many original ones were unable to stand up to time and the elements and had to be replaced with new ones. That darned UV damage thing again!!!! Anyway perhaps the previous owner was just too cheap to buy a new one so plywood filled the need to keep the critters out. Good luck Ed
BIGED52 is online now   Reply With Quote
Old 02-20-2006, 05:32 AM   #7
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Turning A/C hole into skylight
I'm thinking of removing my unsightly "humpback" A/C (a "BayBreeze") and putting a skylight over the hole. This would lighten the darkest spot in the trailer--the bedroom of my '72 Ambassador Int'l.--while restoring the clean lines of my twinkie. I think I'll replace the A/C with one of those portable models with the "vacuum hose" hot air venting tube. Has anyone done this? Where's a good place to get durable skylighting plastic?
26.982 amu is offline   Reply With Quote
Old 02-20-2006, 12:51 PM   #8
1972 31' Sovereign
I'm glad you all are getting good use of my thread. lol
But lets get back to my problem. The small plastic domes. I see them on ebay for ten bucks. But there are a few different kinds. Which ones will work on my AS?
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
replacement plastic trim 74Sovereign General Interior Topics 1 09-10-2002 10:44 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
