Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-18-2004, 08:14 PM   #1
ColtSAA45's Avatar
Profile:  Golden Valley , Minnesota
Skylight part question
On my 1962 Safari the Skylight got blown off in very strong winds. I have the shattered dome and the connected brackets. The brackets got broken on the section that attaches to the lifters. My lifters are ok, but my question is are the brackets still available?? Does anyone have this part leftover from a Fantastic Fan install or any hope of mine being able to be repaired? I'm still not sure how the lifters attach to the brackets. Any help would be greatly appreciated. I am attaching photos of brackets. HELP!
ID:	6054   Click image for larger version
Charles
1979 Avion Model M 28'
2005 Ford F-150
1962 Land Yacht Safari 22'--sold
1999 Yukon Denali Silver--sold
ColtSAA45 is offline   Reply With Quote
Old 04-18-2004, 10:38 PM   #2
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Hi Charles,
You're lucky you got yours back. Most folks never see theirs again. The top of the lifter shaft was attached by pressure that expanded to fit over the top of the opening in the hinged angle piece that's broken on yours (sort of like a grommet on a tarp, if you know what I'm referring to). I've seen a few that were repaired by tapping into the shaft and using a machine screw with a wide head to hold it in place. As for the two broken parts that you have, I'm not sure those will be repairable unless you're a patient metal worker with the right tools.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 04-19-2004, 11:41 AM   #3
ColtSAA45's Avatar
Thanks for the info FF. Does anyone have the correct lifters (with brackets attached) in good condition they would sell?
Charles
2005 Ford F-150
Old 04-22-2004, 09:05 PM   #4
Commercial Vendor
Profile:  Corona , California
We have replacement vent operators that have the hinge on them as well.
The old operators can and will jiggle open while in transit, leading to the cover being blown off.
The problem is the spiral operators easlily open when in transit.
We solved that problem by using threaded rod in our operators. They take more turns to open, but they will not open in transit.
Andy Rogozinski
Inland RV Center
Corona, CA
Tri Axle Question HowieE Axles 30 10-27-2004 09:44 PM
Searching for a rear air bag part number stuart2 Airstream Motorhome Forums 7 03-14-2004 02:15 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 08:57 PM
Wheel bearing part #s Ultradog Axles 6 05-17-2003 02:29 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 10:16 AM
