Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 08-23-2004, 08:59 AM   #1
nevisstudio
nevisstudio's Avatar
Profile:
Images: 8
Skylight Insight
HELLO ALL..
IM TRYING TO PUT A SKYLIGHT IN THE FRONT OPENNING, WHICH MEASURES 14"x25"....
HAS ANYONE DONE AN OPERABLE ONE OR FIXED..
WOULD LOVE TO KNOW WHICH ONE U USED AND PROS/CONS...
THANKS
RICH
nevisstudio is offline   Reply With Quote
Old 08-23-2004, 10:37 AM   #2
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Hi Rich,
When I purchased my trailer, it was missing the big skylight cover. In the long run, I ended up making one from lexan and two different sizes of aluminum angle. I had a couple of the vent lifters mechanisms and they were utilized so the homemade vent cover operates just like the original was intended. Do you have the original lifter mechanisms? That would be all you would need from the original set up. I've got pictures around here somewhere. I'll post them to this thread.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 08-28-2004, 10:32 AM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
nevisstudio.
We have the replacement "Astrodomes" both in milk white and solar gray.
We also have the lift operators.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Sky Light Problems jalewis Roof Vents, Skylights & Fans 12 05-07-2008 08:51 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
Double seals on skylight? TomW Roof Vents, Skylights & Fans 1 03-01-2004 09:44 AM
Diesel Mtrhm Data 1995 - 2003 phred Airstream Motorhome Forums 0 02-13-2004 07:40 PM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 10:16 AM
