Old 11-17-2010, 05:36 PM   #1
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Shower vent fan help
2007 Safari with identical vent fans in shower and bathroom. My question is, how do you remove them to clean them?
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-17-2010, 07:38 PM   #2
2016 30' Classic
Issaquah , Washington
I'm not sure, but if you call tech support and get an answer, please post it here. I have the same fans in my 2010.
PJohnson is offline   Reply With Quote
Old 11-17-2010, 07:40 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
How about a photo so we can see what you are dealing with?
Vaughan
Old 11-17-2010, 07:58 PM   #4
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Smile
After using our shower vent for several months the fine mesh screen clogged with dust. Using a vacuum cleaner with a small brush device attached to the hose cleaned the screen quickly without having to remove anything.
TEXAS66
SRW is offline   Reply With Quote
Old 11-17-2010, 08:27 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I posted this somewhere else, but I guess it is just as easy to post it again. Due to the fact that the rotary switch is installed from the outside of the screen and the wires do not have a connector, I used to remove two screws holding the handle and then two more screws holding the screen. Next I would kink my neck while holding the screen with one hand and a vacuum cleaner and/or a brush in the other hand. WHAT A PAIN.
Since then, I have changed the cheap plastic rotary switch with a nice toggle switch. Both my wife and I like the toggle switch much better. Now since the toggle switch goes through the top of the screen, with a nut on the bottom, it is much easier to do. I still remove the two screws holding the handle and the two screws holding the screen, but now I remove the nut holding the much nicer toggle switch and the screen is free to take to a brush, a vacuum cleaner, or the water hose for a really clean screen.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-17-2010, 09:02 PM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
Bob, You're right - those powered vents are a real 'pain' to take apart to just clean the screen!
I installed a complete new unit when we got our AS a couple of years ago, and it recently up and quit!
I started to dismantle it from the inside as your pic's show, and found that the cheapo push button switch was 'open' - a real disappointment, as we never even use that switch - it's 'ON' all the time and we always use the remote switch in the rear bath wall instead...
Instead of looking around for another switch (your toggle looks good), I just 'shorted' across the cheapo switch so it's 'ON' all the time...
When I had the screen out of ours, I turned on the fan and squirted the fan cage with some electrical contact cleaner (spray can) to remove the dirt and blow it onto the roof, where I then hosed it off...
That little fan really moves some air, and is a valuable appliance to keep up and running!
Ray
Ray & Pat; Morada, CA
Old 11-18-2010, 05:02 AM   #7
deauxrite's Avatar
Excellent information guys. Many thanks for the photos, as I will be doing the same modifications!
Shower Exhaust Fan Waynon Roof Vents, Skylights & Fans 11 05-28-2017 08:38 AM
1988 Excella 32 ft. Shower Fan Frank&Mike Sinks, Showers & Toilets 4 05-11-2009 03:42 AM
Bath vent fan m garrison General Interior Topics 0 11-25-2008 11:41 PM
vent fan Judy Barde Roof Vents, Skylights & Fans 2 06-02-2008 09:06 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
