Old 04-26-2011, 05:10 PM   #1
HCR
HCR's Avatar
Livingston , Full time traveler
Shower fan screeches!
Likely problem and fix?
As always, thanks in advance.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 04-26-2011, 05:31 PM   #2
x
XXXX , XXXX
Look and see if the fan blades are contacting the screen.
wasagachris is offline   Reply With Quote
Old 04-26-2011, 05:34 PM   #3
HCR
HCR's Avatar
Blades NOT touching screen.
Old 04-26-2011, 05:44 PM   #4
1985 31' Excella
Fresno , Texas
The fan motor bearings or bushing are probably dry. If you can get some WD40 on it you can probably quiet it back down. It would be better if you can actually get some sewing machine oil to each end of the motor. But that will require removing the fan assembly.
Wsmith is offline   Reply With Quote
Old 04-26-2011, 08:08 PM   #5
Ottawa , ON
To me, WD40 isn't a fix. Anything I've used it on as a lube was always only temporary. I think of WD40 as a cleaner.
Some disassembly may be required, but oil is going to last longer. Have you looked at how much a new fan is, as a comparison?
Old 04-26-2011, 08:40 PM   #6
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I've got this old lady neighbor that screeches.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-26-2011, 08:46 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Takes more oil and considerably more disassembly.
Vaughan
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
Do you use your shower? Scott J-24 Sinks, Showers & Toilets 117 01-16-2012 04:43 PM
Fan Motor Okiegent Roof Vents, Skylights & Fans 19 05-15-2011 11:58 AM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
Original Shower Curtain for 1967? star kitty General Interior Topics 3 02-19-2011 08:49 PM
