Old 09-23-2006, 09:36 PM   #1
Waynon's Avatar
1986 34' Excella
Shower Exhaust Fan
Can someone help me. The shower vent has a plastic handle to push open and pull closed. I recently had a nephew pull closed too hard and broke the handle. I had often wondered why there was not an exhaust fan in the shower. In looking at how to replace the handle I noticed that there indeed is a wire there for a powered exhaust fan, but evidently was at some point removed by the PO. I removed the screws from the inside but this only took off the decorative trim and there is no access from the inside. Can this whole unit be unscrewed and replaced from the outside -- fan, handle and all? If so where can I get it and what would I ask for.
Waynon
Waynon is offline   Reply With Quote
Old 09-23-2006, 09:40 PM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Do a search for the manufacturer, Ventline. You will also find them on the WEB.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 09-23-2006, 10:34 PM   #3
Waynon's Avatar
1986 34' Excella
Shower Exhaust Fan
Well, I was able to get the inside plastic "screen" cover off. Not only is there a wire there, there is a little motor with an unattached switch just hanging loose. I tried the switch, a rotary one, and it still works! The shaft comes out the top, but there are no fan blades there. There is no hole for the switch to come out of. How would it have originally worked? What do I do to get it fixed?
Waynon
Old 09-24-2006, 12:38 AM   #4
Waynon's Avatar
1986 34' Excella
Ventline Shower Exhaust Fan
Thanks Peegreen. When I got the cover off I see that it says Ventline Group, Model VP, 12 volt. On the Ventline web site they list their products but shower vents are not included.
I'd sure like to know if a replacement fan blade can be purchased and I am stumped as to how this things switches, since it is obvious that the little switch that was tucked away inside can't be reached when the exhaust is assembled.
Hope someone can come up with some answers.
Waynon
I tried to upload some pictures, but get msg "page cannot be found".
Old 09-24-2006, 01:41 AM   #5
Waynon's Avatar
1986 34' Excella
VENTLINE search
Thanks to Peagreen! I had searched using shower, exhaust, fan, and got many! pages of interesting but not relevent information. Once I realized that you meant search HERE for manufacturer's name I found several threads and sources, complete with directions and descriptions. Thank you very much!
Waynon
Old 09-24-2006, 04:18 AM   #6
peegreen's Avatar
You can purchase a new blade from Ventline for about $5. The only problem is the hole in the blade no longer matches the shape of the motor shaft, "D" vs "spline". I had to replace the motor which forced me to replace the blade. Not such a bad idea since everything was apart anyway and considering the age.
WBCCI 24291
New England Unit
Old 03-10-2007, 08:52 PM   #7
newbie
audiobox's Avatar
Fort Wayne , Indiana
Our recently acquired '87 Excella is close to both of your years. The shower exhaust fan is unbelievably noisy. After you replaced your fan, Peegreen, does the new set up run fairly quietly?
Craig
http://www.septaudio.com
audiobox is offline   Reply With Quote
Old 03-10-2007, 09:01 PM   #8
WayWard Wind's Avatar
2004 25' Safari
try this
I'm in the process of repairing our ventline bath fan--our fan l has a "spline"shaft & I ordered it from Ventline. Call 574-848-4491- ask for Jennie she's a real help. WHATEVER YOU DO ---keep those 2 little screws that hold the motor in the bracket under lock & key. Yep---I lost mine & can not find replacements. BTW our unit is an 04.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 03-11-2007, 04:54 AM   #9
Waynon's Avatar
1986 34' Excella
New bathroom fan
Just noticed that some questions didn't get answered. I finally just installed my new vent fan yesterday. I wanted a new blade and a new switch. It was cheaper just to buy a complete new set and I'm glad I did. Twenty minute job changing it out and the new fan is really quiet.
Thanks again to the forum for the info.
Waynon
Old 07-25-2011, 03:58 AM   #10
georgetown , Texas
We need just a new blade for our bathroom vent fan. I cannot seem to find the part number for the fan blade? I'm thinking of just measuring and going to a RV supply store. (We cannot find the old blade). We have a 1997 Safari. Please help if you know the part number for the fan.
mindagray is offline   Reply With Quote
Old 05-03-2017, 10:55 AM   #11
2005 22' International CCD
Wayland , Michigan
Help please - where can I purchase a replacement handle for the open/close shower vent?
Vic McCarthy is offline   Reply With Quote
Old 05-28-2017, 08:38 AM   #12
Engineer Rich
engineerich's Avatar
1992 35' Airstream 350
San Antonio , Texas
Still looking? I just replaced the entire fan unit out of my RV bathroom...have the old handle...
engineerich is offline   Reply With Quote
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
