Old 06-20-2015, 10:19 AM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Sealant for Fantastic Vent ?
Not going to use the foam gasket provided with the fan. I am thinking about using Trempro 635 in place of the gasket and to seal screw heads and top of the flange. I see a 2010 thread on the subject---will Trempro 635 do the job or should use Sikaflex or something else? Love the Vent --have it hooked up just waiting to order the sealant. Thanks, Don
glacierrunne is offline   Reply With Quote
Old 06-20-2015, 12:23 PM   #2
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I just installed two new Fantastics on our '96 34'er. I used the closed cell foam gaskets that came with them. Be advised the 14 x 14 holes in the ceiling of the AS should have a 2 x 2 frame between the inner ceiling panels and the roof panels. It will give you a lot more "meat" to screw the Fantastic frame to the roof than just the thickness of the aluminum.
Then to seal the frame to the roof, I used 3" wide Alumabond to cover the screw heads.
For whatever it's worth
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is online now   Reply With Quote
Old 06-20-2015, 04:31 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I have installed a FF on my thread below that was done differently then any other on the forum. It's toward the end of the thread
Old 06-20-2015, 05:45 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I set my fans with butyl tape, then sealant on the screw heads and edges of the flange.
2012 Dodge Durango Hemi/AWD
Old 06-21-2015, 10:52 AM   #5
1996 25' Excella
Tillsonburg , Ontario
Sikaflex is absolutely permanent but it will be difficult to remove the installation if need be down the road. If you are using any tape or strip mastic be sure it is tight fitting all the way around and a little bit overlapped at the corners.
Good point about the support between he aluminum skins. I used Sikaflex to bed the new batwing antenna. The mounted antenna flexed quite a bit...wish I had the advice about the wood filler back then.
JCW
JCWDCW is offline   Reply With Quote
Old 06-21-2015, 01:44 PM   #6
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
About four years ago I had two of the Fantastic vent fans installed in my Airstream by Southwest Coaches in Irvine, CA. They used Sikaflex in their installations.
WindyJim is offline   Reply With Quote
Old 06-21-2015, 08:35 PM   #7
Jim&Teach
1976 31' Sovereign
Portage , Indiana
Took Lucille our '76 31'. LY on her maiden voyage. Lots of leaks. Interested in a good sealant. What type of roof are you using?. Mine is bad. Not looking to keep it the original. Any advice greatly appreciated! Jim Teach Lucille.
jimmbob is offline   Reply With Quote
Old 06-21-2015, 08:38 PM   #8
Jim&Teach
1976 31' Sovereign
Portage , Indiana
Sorry what type roof vent are using?
Old 06-21-2015, 09:29 PM   #9
1980 20' Caravelle
I have a Fantastic vent in place and is running as we speak. It is sitting on the provided plastic gasket with 8 screws holding it down. I am reading all the responses to this thread before I decide on the sealant to use. Thank-you to all you guys for your imput! Don
Old 06-22-2015, 05:39 AM   #10
1996 25' Excella
Sikaflex! Second choice for me would be an industrial grade acrylic caulk... you want a non-curing caulk...no silicone. Silicone shrinks and pulls away especially if there is residue from the last install.
I like MONO brand but it may be available only in Canada. There are lots of good brands in the US. Go to Ace or someone in the construction supply business
JCW
Best sealant for exterior stove vent? bonginator Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 08-04-2014 10:55 PM
Removing sealant around my vent pipes on a1989 345LE Motorhome. maxr Classic Motorhomes 0 03-22-2011 08:29 PM
Roof sealant removal and a leaky fridge vent Rob&Julie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-02-2010 05:47 PM
Fantastic Vent R&SZinser Roof Vents, Skylights & Fans 11 11-30-2005 07:56 AM
sealant @ Furnace vent cap BURNZEE Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-29-2005 12:27 PM
