Old 08-31-2010, 01:06 PM   #1
2004 25' Safari
Rochester , New York
Unhappy Roof Window/Skylight Replacement
I own a 2004 Airstream Safari. A few years ago the rear roof window was open during a windstorm and was broken off. A replacement was bought and installed but it was not the correct size window and leaks during heavy rain. Does anyone know of a website/store that I can buy the correct size roof window.
alecg is offline   Reply With Quote
Old 09-08-2010, 08:46 PM   #2
2008 23' International CCD
Denver , Colorado
Totally. The OEM was junk - see the threads about the cracks in those original roofs thanks to poor factory installations - and leaking despite about 30 pounds of caulking. Get with Inland RV. We just bought a new roof window from them via the web site for our 08 International.
Take the measurements, talk to Inland. Check the thread here for how to remove the old skylight.
I used Sikaflex caulking and not the 3M Marine 5200 which I hear is NOT right for plastic skylights. Remove the old skylight by leveraging a strong putty knife under the edge and between old caulk and metal frame. Scrape and wire brush the old caulk down to bare metal.
Line up your new window on the clean metal frame around the window opening. Don't use the original holes in the metal frame. So you have to line up the new window and mark new locations. Be careful not to drill too far towards the edge of the aluminum frame.
Carefully first drill the skylight holes as marked. Then set the skylight onto the metal window frame, its holes lined up where you want, and drill through the aluminum using the plastic holes as a guide. The plastic holes are larger than the aluminum ones. Inland gives you the correct sizes. They were great to talk to on the phone too once I had all my parts together and was nervous about where to begin.
I used a healthy bead of Sikaflex on the aluminum, got sheet metal screws with built in washers, added rubber washers. Set the new window down on the frame, press it into the Sikaflex, align the holes. Then I put a good dose of caulk in each hole and screwed down the screws by hand, not with a power tool so as to not over-torque the screws and crack the window. Check out your processes, your measurements, your replacement size, the caulk, screws and so forth. It took me the afternoon to do it carefully. Oh, and stretch a sheet of plywood on the roof between rafters to allow you to step carefully on the roof.
Good luck. Inland was a big help over the phone. The new window looks marvelous. No leaks, either.
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
skylight replacement lrwarren Roof 22 06-19-2016 08:29 AM
Sealant for roof vents & skylight? Dodge Man Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-31-2013 06:43 PM
Replacement skylight shade titleists General Interior Topics 0 08-15-2010 11:59 AM
skylight replacement lrwarren Roof Vents, Skylights & Fans 5 08-19-2009 04:38 PM
Roof Leaks-skylight-2005 Safari KJJorgen Roof Vents, Skylights & Fans 5 04-27-2009 10:00 AM
