Old 07-18-2007, 08:48 PM   #1
SLVRSRFR's Avatar
Orange city , Florida
Send a message via AIM to SLVRSRFR
Roof vents leak...
Greetings from sunny muggy Florida!
As we all know; Florida rains every day in the summer. Joy. I am currently full timing in my 31' 1974 Soveriegn. For obvious reasons I have noticed a small problem. The lights in my dining room and bathroom are filling with water. They are the big rectangular 12volt lights with ventalation. I believe the water is entering through a bad seal.
My goal is to take the assembly apart nd remove the old seal with a razor etc. then use some good old #III silicone. I hope this will resovle the problem and prevent further water damage. however the people here on A/Sforums may have some better suggetions on tackling the problem.
SLVRSRFR is offline   Reply With Quote
Old 07-18-2007, 08:48 PM   #2
SLVRSRFR's Avatar
Thank you in advance!
Old 07-18-2007, 09:10 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The vent fans on my '77 Excella 500 31' had foam rubber seals on the inside of the vent hood. They were all shot, I replaced them but no water ever leaked into the interior prior to the seals being replaced. I'd say you may also have Vulkem that has cracked, chipped or fallen off on the outside of the trailer around the vent. It may be time to scrape it off and recaulk with Vulkem, Trempro or Sikaflex.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-18-2007, 09:59 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Don't ever use silicone on the exterior of an airstream. Use Vulkem.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-18-2007, 11:17 PM   #5
There are two sources of leaks from your vent covers.
The first is probably the gasket is shot.
The second is if your vents are metal and have a plastic center piece, that plastic in time fails. Or if your vent covers are all plastic, they could be cracked.
You might also check your window and entrance door gaskets as well as the access compartment door gaskets. If they are the originals, most of them will leak especially when you tow or are in a driving rain.
Plus, the # 1 hidden gasket that fails, since it only lasts 5 years or so, is the sewer vent pipe gaskets. You will have to remove one of those covers to check it out.
Old 07-19-2007, 09:16 AM   #6
SLVRSRFR's Avatar
Thank you for the advice guys. Vulkem got it... No silicone. Good thing I asked. What can I say... Im a nOOb. Be safe out there!
Old 07-19-2007, 11:37 AM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have used some silicon. Should I get it off?
SuEllyn & Brian McCabe
Old 07-19-2007, 11:41 AM   #8
Faster than yesterday.
The sun will make the silicon sealer release. That created a chemical barrier, that must be chemically cleaned so that you can use the correct sealer.
Never, ever, use silicone sealer on the outside.
Old 07-19-2007, 11:54 AM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Red face The Shame of It All
Hi Andy,
Yes, I have silicone on my 67. In my defense, it was in the mid-80s, no forums for advice. I've been very lucky so far, but could you expand on the chemical cleaning after removing the silicone? I will fix it correctly.
Vaughan
Old 10-01-2007, 03:11 PM   #10
Floresville , Texas
Can you use eternabond products on Airstreams (i.e., their tape etc)?
rreeves is offline   Reply With Quote
Old 10-01-2007, 04:21 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Sewer Vent Leak
This is what I found while cleaning the roof....CHECK THAT SEWER VENT!!
http://www.airforums.com/forums/f456...ent-35651.html
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 10-01-2007, 05:12 PM   #12
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
My trailer had silicone on it from a previous PO. I removed it on Saturday using a product called "Indoor/Outdoor caulk remover" by 3M. It comes in a squeeze bottle and looks like white wood glue.
It seems to work by loosening the bond to the aluminum, the silicone stays intact. A plastic putty knife under the edges pulled it right up. Works great.
Dave
Fyrzowt is offline   Reply With Quote
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 09:37 PM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
