Old 10-25-2011, 01:10 PM   #1
1981 31' Excella II
New Market , Alabama
Roof Vents
The roof vents on my 81 Excella II are deteriorated and leak. I was thinking of just covering them with aluminum to replace the cracked plastic. The amount of light that comes through them is minimal so I figure Aluminum would be a lower maintenance option. It looks like there is a top surface piece of plastic and another one below that. Is this done to add some insulation? I may also insulate them. The way these things are designed not much air can get out. There is the big light diffuser on the bottom and then a metal boot that comes down below that. Unless there is a fan in there I can't see the vent being open or not is going to make much difference. I am not going to destroy that function just put metal where the plastic is that is pretty much gone already.
Perry
Info on '68 roof vents. Nomadtek Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-22-2011 11:47 AM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
Roof Vent Insect Screen Installation Guym General Repair Forum 2 05-06-2011 07:08 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
