Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 08-27-2005, 11:02 PM   #1
skidmark
Profile:
Roof vents
I just bought a 69 31 ft. soverign, My roof vents are in bad shape. Can I buy new ones? or should I have a fabrication shop make them of aluminum?
skidmark is offline   Reply With Quote
Old 08-28-2005, 07:09 AM   #2
fastrob
fastrob's Avatar
Profile:  1976 25' Tradewind
Mount Vernon , Maine
Roof Vents
If you do a search, blue bar at top of page, for roof vents, I bet, you will be surprised at how much info there is.
There is a wide spectrum of views here. I like the roof vents that do not leak when it rains. Some have automatic controls with thermostats. Some of the old vents loook cool so consider fixing what you have.
The venders for parts are plentyful and competitive. Some parts are hard to find so when supply is scarce prices might be high. This forum can be very helpful and fun.
fastrob is offline   Reply With Quote
Old 08-28-2005, 09:46 AM   #3
Ohanastar
Ohanastar's Avatar
Profile:  1964 24' Tradewind
Cardiff , California
Vent Info
Congratulations on your "new" 69! The forums here are very helpful about roof vents. Another great source of info can be found at www.vintageairstream.com. That website has a section about Restoration Rescources and a subsection about repairing Roof Vents and Covers. I was able to find a replacement Astrodome for my 64 Tradewind at www.airstreamdreams.com but, according to what I've read, I THINK InlandRV might have one that fits the 69 a bit better. And, don't forget EBAY! I've become ADDICTED to that site for those random extra parts that I can't locate elsewhere! Good luck and welcome to the Forums!
Ohanastar is offline   Reply With Quote
Old 08-28-2005, 03:34 PM   #4
LowellN
LowellN's Avatar
Profile:
I have the skylight roof vents on my '75 Sovereign, and they were in bad shape. With a little work, a sheet of plexi-glass, some vulkem, a drill and some rivets I repaired the orig. "glass" in the roof vents. No leaks, and now they actually let some light in.
Lowell
"For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move."
Robert Louis Stevenson
LowellN is offline   Reply With Quote
Old 08-29-2005, 09:13 PM   #5
skidmark
Profile:
Thanks for the reply
Old 08-30-2005, 03:51 PM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Skidmark
Plexiglass should never be exposed to the sun. To do so will cause it to crack and craze in a matter of weeks.
New vent covers are available with thermal barriers, in milk white and solar gray, both for your solardomes and astrodome.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 08-30-2005, 04:25 PM   #7
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
plexiglass
Use Lexan instead of plexiglass. Lexan holds up much better....used it on sailboats for the same function. No need to spend much ordering something, just have a piece cut, tape and drill out the holes, caulk & rivet it in.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 09:37 PM
Roof Air Problams 1985air345 Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 7 10-03-2002 01:06 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
