Old 12-26-2009, 03:36 PM   #1
1969 27' Overlander
Kansas City , Missouri
roof vent replacements
I am rehabilitating a 69 Overlander which has missing/broken roof vent covers. I need suggestions on vendors for replacement roof vent (covers). One cover is square and incorporates an exhaust fan. Dimensions are approximately 12 by 12 inches; it opens on a hinge with a single crank. The other cover opens with two cranks and lifts the cover straight up (not hinged) the dimensions are approximately 12 by 24 inches.
mmcpherson is offline   Reply With Quote
Old 12-26-2009, 03:41 PM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Both Inland RV Center - The Nations Leading Expert in Airstream Innovations and Vintage Trailer Supply - Vintage travel trailer parts and supplies! have the vents that you need. You can decide which vent you want to purchase.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-26-2009, 07:51 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
One more place to look at is here. Out-of-Doors Mart
Common replacement vents are Maxxfan General Overview and FanTastic Vent - Home Page. I have used both with good results.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 12-27-2009, 09:42 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you decide to replace the 14x14 vent with either a Fantastic or Maxx-Air, you'll need to remove the old one and slightly modify the location. Here is a link to a brief tutorial:A Fantastic Story
Old 12-27-2009, 03:51 PM   #5
1963 19' Globetrotter
Moline , Illinois
Nice tutorial, my new Fantastic fan and Intellipower are sitting in my shop just waiting to be installed. Sounds like it isn't too bad a job. Now I just need to get my newly installed replacement knee healed so I can get up on the roof.
63air is offline   Reply With Quote
Old 04-05-2010, 11:02 PM   #6
rollin home's Avatar
1992 36' Land Yacht
Oroville , California
roof vent cover
I have been having tarps on the roof...the leaks keep coming even after caulking by me and by the shop.....and now i was up there re-adjusting tarps and cracked the sky light
so i need to replace it...hopefully i can just replace the sky light part...depending on what the hinge is...the good news is that i did not fall off and break my neck while stumbling around up there with the flu and a fever....any clues will be appreciated.
Laurel
it is a 92 airstream land yacht motor home....
rollin home is offline   Reply With Quote
Old 04-06-2010, 06:30 AM   #7
Well Preserved
1993 21' Sovereign
Laurel
Does your motor home have a Fantastic, or other "standard" vent? If it's a Fantastic, you can simply give them a call, and they'll send you a new cover. If it's one of the "cheapie" ones with the small fan in the corner, it would be a good idea to consider replacing the assembly with a Fantastic or Maxx-Air vent while you're doing the work.
Old 04-07-2010, 12:47 AM   #8
1992 36' Land Yacht
roof vents, skylites, fans
Mine is the old style...maybe someone has removed an old one to put in the maxi fantastic ones, and has the old one still laying around somewhere?? Laurel
vent covers, roof vent
roof vent??? tacoman All Argosy Trailers 3 07-04-2009 10:54 AM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 05-01-2008 12:13 AM
What to do with with vent in the roof? 58BUBBLE Roof Vents, Skylights & Fans 7 03-06-2005 07:29 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 06:44 AM
