Old 12-19-2011, 09:11 AM   #1
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
Question Roof Vent repair
Can anyone help me in finding vent covers that replace old original ones for a 1972 Intl Soverign? The three that are now there leak from years of cracking and distortions. They are plastic with 3 metal rails. Either metal or plastic replacements would do. I am not sure of their brand name, but they don't flip up like contemporary trailer vents.
I would also be interested in added fans to a couple of them.
If I purchased whole new vents (cover and housing), how difficult is replacement? Thanks ahead for any advice - this site is awesome.
litlgeezer is offline   Reply With Quote
Old 12-19-2011, 09:15 AM   #2
To replace the vent covers, you will have to get up on the roof.
Old 12-19-2011, 10:26 AM   #3
1972 31' Sovereign
1979 29' Ambassador
been there, done that
Old 12-19-2011, 10:30 AM   #4
1974 Argosy 20
Kooskia , Idaho
Probably the best thing you can do is to replace them altogether with something like a Fantastic Fan vent. That way you will get all new parts, and a much better fan which uses far less power while moving a lot more air.
Old 12-19-2011, 10:31 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There are several Airstream dealers that have those parts. You can call around or check on the web. The fan motors are the same as the fan motors on the stove vents of the same era.
Old 12-19-2011, 11:22 AM   #6
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
what idroba said
Fantastic or maxxfan 1000% better 1000% more quiet 1000 more air circulation. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-07-2012, 11:40 AM   #7
1972 31' Sovereign
1979 29' Ambassador
new vents
Purchased 2 crank vents and 1 fantastic fan vent from Vintage Airstream. Folks were nice and vents were shipped quickly.
Now, I have to figure just how to install them as I do want to ensure that there are no leaks when I finish.
I read about Olympia? style rivets. Are these rivets necessary verses common aluminum rivets from the hardware store? I notice that the trailer rivets have rounded heads with a few exceptions where repairs have been made. Should I purchase these Olympia rivets for the vent installs? Do I risk leakage with the other common hardware style?
Also, Vintage sold me tubes of 'Trimpro 635' to seal the flanges. The metal crank vents did not come with gaskets. I guess flat rubber would be appropriate material to make gaskets.
Old 01-07-2012, 12:22 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You can forget the gaskets and just use a good bead of Tempro or Vulkem. The tempro will form an adhesive water tight seal. You can use regular hardware store rivets. The Tempro seals and holds the vent to the roof and the rivets hold it in position. The Olympic rivets do have more grip, but are preferred because the head cosmetically looks like the original bucked rivets. You are going to cover the rivet heads with Tempro anyway, and unless you hosting dancing on the roof only you will know.
Old 01-07-2012, 12:53 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
If they are plastic they are not original. The original were aluminum. Some had a solid center, some plastic to act as a skylight. If they are all plastic they are probably standard 14" roof vent covers. You can get them at any RV supply.
Old 01-07-2012, 12:59 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
Now, I have to figure just how to install them a.
If the original roof vent holes have not yet been modified you will have to. The original roof vent holes have rounded corners. You will have to square the corners and do a little trimming to get the Fantastic Fan to fit. No big deal. The main thing is wiring for the trailer runs close to the roof vents. Be careful you don't cut it by accident.
Old 01-07-2012, 01:17 PM   #11
1981 31' Excella II
New Market , Alabama
My vents had a metal frame with some white plastic inserts. I made some solid aluminum inserts and pop riveted them to the existing frame. I don't think they will leak again in my lifetime.
Perry
Old 01-08-2012, 07:26 AM   #12
1972 31' Sovereign
1979 29' Ambassador
Thanks for your information, esp about the rivets.
As for the vent, the flange is not flat, but has a recessed lip of abt 1/8" depth that appears to have been made for a gasket. If I don't use a gasket, I think the riveting will distort the vent flange and may enable water seepage. Kind of puzzled why gaskets were not included.
Old 01-08-2012, 08:10 AM   #13
1981 31' Excella II
Do you have a photo of what your vent looks like?
Perry
Old 01-08-2012, 08:33 AM   #14
All vent covers that open, must use a proper gasket.
If not, they will leak in a blowing rain.
Leaking roof repair & impact on resale value idahospuds21 Trailer Values 6 05-27-2011 04:04 AM
Roof Vent Insect Screen Installation Guym General Repair Forum 2 05-06-2011 07:08 AM
Drainage system roof vent is missing.. Luc_DK Roof 13 03-30-2011 05:28 AM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
