Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 12-08-2003, 05:25 PM   #1
Alex
Alex's Avatar
Profile:  1972 29' Ambassador
Parker Dam , California
Question Roof Vent Opening
Can anyone tell me what the two vent opening on the roof along the right side, near the awning area are for?? Mine are exposed and water can go straight through into them, are they supppose to be covered??
I'll try to download a picture
Alex is offline   Reply With Quote
Old 12-08-2003, 05:30 PM   #2
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Vents
These are air vents for the fresh water system. Yes they are open but have a gasket at the base to prevent water from coming into the trailer.
The gaskets must be replaced from tinme to time around $6/$7 to replace. Do a search on vents or visit the Inland RV site for additional info.
Garry
Old 12-08-2003, 05:36 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Alex.
The polished metal vent pipe covers are for the black and gray tank vents.
They have nothing to do with the fresh water system.
Upon removing a cover, you will find the gasket cracked. The gaskets are cheap. When a new gasket is installed, a bead of vulkem sealer must be applied from the inner circle of the gasket, through the screening and on to the black pipe.
That gasket, depending on climate, lasts from about 4 years to about 10 years.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 12-08-2003, 05:43 PM   #4
garry
garry's Avatar
Duh; like the sink drain is grey water !!
Thanks for the correction Andy don't know what I was thinking.
Did get the "visit Inland RV site correct"
Garry
Old 12-08-2003, 05:49 PM   #5
Commercial Vendor
Garry.
That gasket is listed and shown in our web site as you stated.
Part number 45701.
Inlandrv.com
800-8777311
