Old 02-17-2014, 09:32 PM   #15
1973 31' Sovereign
Northglenn , Colorado
Just got my lexan lid covers from Vintage Trailer supply. Not cheap though 69.99 each. replaced all 3. Wanted to keep my lights stock. As for the metal parts, you might want to check with airstream bone yard places, or post a classified ad since many folks upgrade to new lights and vents. Good luck.
RockinU2 is offline   Reply With Quote
Old 11-14-2014, 12:02 AM   #16
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
rusted tight
I can't budge my crank either. Must be a common problem. I think I'll try the guy who said bend it in till it passes the outside opening and slide it out.
terrencecolp is offline   Reply With Quote
Old 11-17-2014, 02:47 PM   #17
1970 25' Caravanner
Incline Village , Nevada
Your crank is different than mine. But I ended up using a hacksaw to cut to the bolt. Then I bent the alum enough to pull bolt out. I was able to get it all back in and bent back. It works great now. My pic is at the first part of this thread
Jeremy9107 is offline   Reply With Quote
