Old 03-12-2011, 09:06 AM   #1
Stubborn but learning
filterman's Avatar
1973 31' Excella 500
washougal , Washington
Roof vent covers
I have a original roof vent covers, the square ones and they are aluminum with a thin sheet of plastic. I want to keep the aluminum and replace the riveted plastic top portion. which type of smokes or clear plastic can I use to recover these with that will be uv stabilized?? Lexan? Plexi? Or just get some quarter inch glass and wuse sikaflex and window tint it?? Thanks
filterman is offline   Reply With Quote
Old 06-15-2011, 05:52 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Lexan polycarbonate would work well.
Lance
Top is offline   Reply With Quote
Old 06-17-2011, 08:49 AM   #3
PJ Beans's Avatar
1981 27' Excella II
Sachse , Texas
I just used the standard 1/8" smoked plexiglass found at Home Depot. It is working very well. I replaced both the inside and the outside with the smoked plexiglass.
PJ Beans is offline   Reply With Quote
Old 06-17-2011, 11:09 AM   #4
1985 31' Excella
Fresno , Texas
Lexan polycarbonate is the best for the outside because it has a lot more strength. I just replaced all of mine about two months ago. I put polycarbonate on the outside and plexiglass on the inside. Be sure to use exterior foam if you replace the gasket on the lid.
Wsmith is offline   Reply With Quote
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 12:56 PM
Shorten crank on roof vent? Breadbug Roof Vents, Skylights & Fans 4 01-31-2011 10:43 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 05:58 PM
