Old 05-04-2010, 06:34 AM   #1
GnJ
2005 22' Safari
Weirsdale , Florida
Roof re-enforcement/ patch
Yesterday, I removed the Fantastic Fan from the front of our 05 Safari (PO had installed it sideways) to the correct back to front opening.
Upon removal and the start of cleaning off the sealant, I found that:
the PO had enlarged (hacked) the opening to 14 5/8" and had split/ripped the skin in two places, one about 3-1/2" and the other 2-1/2" covering them with a cellophane tape and tons of sealant.
I am going to make a re-enforcement piece to cover the ripped skin and to reduce the size of the opening.
Should I put the "patch" inside or outside? I am leaning toward the outside..
GnJ is offline   Reply With Quote
Old 05-04-2010, 07:52 AM   #2
1977 Argosy 24
Milltown , Wisconsin
Outside so water does not pool in it.
ventport is offline   Reply With Quote
Old 05-04-2010, 08:00 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I agree - put the patch on the outside.
replace skin or patch wol Ribs, Skins & Rivets 8 10-01-2015 07:07 PM
Patch Piece digger bear Ribs, Skins & Rivets 2 06-13-2008 04:45 PM
Is a patch so bad? CampSayler Ribs, Skins & Rivets 22 10-12-2004 10:44 AM
How do you patch Bullet holes? 59toaster Ribs, Skins & Rivets 5 10-26-2003 08:08 PM
