Old 04-09-2008, 01:10 PM   #29
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
Yeah, I was only going to have a go at the lifter brackets, they are just folded, not from an extrusion right?
Petethefeet is offline   Reply With Quote
Old 04-09-2008, 01:14 PM   #30
The old style vent operator brackets, were made from a strong steel.
I have no info as to what grade of steel was used. Could be spring steel.
Old 04-09-2008, 02:31 PM   #31
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 31
Pete (and everyone),
Thanks for all the great information in this thread. The Astrodome in my '61 Overlander has been removed by a PO and the frame & brackets are missing. I had no information about the fabrication of the frame & brackets. I need to get started and order the Astrodome & vent lifters.........now, there's no reason to wait.
Good luck!
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 04-10-2008, 10:38 AM   #32
1964 30' Sovereign
1957 26' Overlander
Images: 14
Mmm. It could be a job for my local engineer shop after all.
Old 04-10-2008, 06:16 PM   #33
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
The lifter bracket is made out of 0.060 inch sheet steel or 1.5 mm if your using metric. I think it can be made out of standard steel sheet stock.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 04-12-2008, 01:48 PM   #34
1964 30' Sovereign
1957 26' Overlander
Images: 14
Thanks for that conversion, I think I will have a go at it now, I'm going to be doing a few imperial/metricconversions myself when I make that template. I'm not too bad on lengths and the like, it's volumes that I scratch my head about sometimes. You have all been such a help.
Old 04-12-2008, 01:53 PM   #35
1964 30' Sovereign
1957 26' Overlander
Images: 14
Good luck!
Great! I'm glad I could play a modest role in helping to get a problem discussed that others are interested in too. I was wondering how common it was, as all my trailers have it, regardless of year. I was thinking it might be due to it being the foremost vent and therefore copped the most damage first as it was being towed, or maybe because as it is the largest vent, it has more area exposed.
Pete
Old 04-28-2008, 02:42 AM   #36
1964 30' Sovereign
1957 26' Overlander
Images: 14
Waahey! Just got my recycled roof surround back, from my friend the reluctant welder. Gave it a clean and painted with zinc rich paint. It is'nt perfect by any means but should be good to go now and may even be able to reuse the gasket surrounding the top, I hope to get it installed very soon.
Old 04-28-2008, 03:35 AM   #37
Baltimore , Maryland
Now that is a good looking solution.... have you seen this thread http://www.airforums.com/forums/f455...tch-37829.html ? A possible alternative to the regular....
Old 04-28-2008, 03:48 AM   #38
This seller must read the forums and list the things being discussed... I have seen this happen a few times now. eBay Motors: AIRSTREAM ROOF VENT CURB SPARTAN SILVER STREAK TRAILER (item 220229164134 end time May-04-08 18:16:12 PDT) Start a thread about where to find used floor tiles and within a few days he will list those.
Old 04-28-2008, 04:02 AM   #39
Images: 59
That's pretty effective. Another great thing about Airforums.
I did note the 'all aluminum' roof vent curb is pretty rusty.
Old 04-28-2008, 04:17 AM   #40
That seller chops up a lot of trailers... sure hope they are all salvage and not bought just to chop apart.
Old 04-28-2008, 12:38 PM   #41
1964 30' Sovereign
1957 26' Overlander
Images: 14
Yeah, I have seen that thread, it's great, and I do really like that alternative. I have new lifters which I would prefer to utilize, mainly because of their expense,so probably will not be doing it on the sovereign, but I would like to give it a try on another trailer, those pics of Wally sticking out of the opening just look so classic to me. It is almost like the " Great Helmsman ".
Pete
Old 04-28-2008, 02:29 PM   #42
1964 30' Sovereign
1957 26' Overlander
Images: 14
Mmmmm. Not really ready for used floor tiles yet, but never say never, could use an entire interior skin without any penetrations for the Sovereign though, might get lucky!
What to do with with vent in the roof? 58BUBBLE Roof Vents, Skylights & Fans 7 03-06-2005 06:29 PM
Roof Vent Screens walter1 Roof Vents, Skylights & Fans 2 12-23-2004 11:50 AM
