Old 04-09-2012, 09:56 AM   #1
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
Roof fan squeals
I think I have a Fan-tastic vent. It has the pop in screen, and the speed control is variable (not single speed, or 3 speed). The problem is that it squeals. At every speed. It's not bad; in fact DW did not even notice it until I pointed it out to her. Now she doesn't like the sound, either. Is this motor easy to access and lube? And if so, what would you put on it? Thanks in advance!
Bret
All kids are gifted; some just open their packages earlier than others. - Michael Carr
JazzDad is offline   Reply With Quote
Old 04-09-2012, 10:21 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Contact the company. They have excellent customer service.
Richard
Old 04-09-2012, 10:40 AM   #3
"Cloudsplitter"
Never seen a FV with variable speed, ours is 3spd reversible. Pic?
Anyway...have had good luck using WD40 on the shaft, easier done from above. Have used it on the stove vent motor also.
Old 04-09-2012, 10:50 AM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Check for a pine needle or leaf wedged in there. They can squeal too!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-19-2012, 12:07 PM   #5
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
Give the man a (bubble gum) cigar! I have finally made my way to caulking back there and discovered it to be a SHURflo. http://www.shurflo.com/rv-products/r...ult.html#tab04
Old 04-23-2012, 10:47 AM   #6
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
OK, so now that we know it's a SHURflo, it's time to re-caulk that puppy. Guess what? Just like the skylight, the 'good' folks at JC put a major whump on the screws attaching it to the roof.
1st photo; cracks are not too bad.
2nd photo, crack goes up the side of the roof jack. (Sorry about the focus.)
So, what do you think? Should I replace the whole fan assembly, or just glob LOTS of caulk all over it? In advance, thanks!
ID:	156575   Click image for larger version
Name:	Long crack.JPG
Old 04-23-2012, 02:29 PM   #7
"Cloudsplitter"
Thumbs up
JD,
When I replaced the skylight last year I used these plastic caps over the screw heads, fill them with caulk press on and let dry. Sika 721 UV works very well.
Your other cracks don't look too bad yet, a good sealing should last, inspect often.
Old 04-25-2012, 09:39 AM   #8
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
Thanks. Yep, caulk and me are the best of buds.
