Old 06-29-2006, 08:39 AM   #15
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Fanatastic Vent tech support reply to my reverse question
Here is what they told me:
"Hi Ken,
If you have a on/off rocker switch in the face of fan you can order a reverse switch to put in place of on/off switch..."
I will be following up with a warranty question (seeing that I'm not a factory authorized tech) but it sounds easy.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-29-2006, 08:51 AM   #16
bradk's Avatar
2006 19' International CCD
Calgary , Alberta
Images: 14
I can't see it being a warranty issue unless you were to put a reverse on the rear fan.
The lady at Fantastic mentioned the install should be straighforward and they include a wiring diagram with the parts package that they send out. I ordered two and it was 24 bucks. Cheap experiment I'd say.
b.
Team Ironcops for Cancer 2006
Raced! Ironman Canada in support of the Canadian Cancer Society
www.ironcopsforcancer.com
We raised over 1.3 Million dollars for Cancer Reseach this year. Great job team!!
bradk is offline   Reply With Quote
Old 06-29-2006, 01:01 PM   #17
silverback's Avatar
2006 28' Safari SE
FYI - Fantastic Vent confirmed it is not a warranty problem for a DIY swap of the switch.
4CU Charter Member
Old 06-29-2006, 02:04 PM   #18
_
hello fantastic fan fanatics......
who knows why......
rvia or just cost savings.....
ff rep acted surprised when i noted that my front ff had no reverse...
he told me other makers still use them....
'perhaps a/s was saving a buck'........
gases arent an issue at the front....
and if front is set to exhaust.....
and rear open or bath open....
fumes can still be sucked in....
without a 3 way function....
anyway
the ff fan tech followed my back to the trailer....
here at the international.....
and installed the 3 way switch in place of the on/off....
took 10 minutes......
and 30$......
warranty intact.....
very nice guys....
they also did a complete inspection of both fans, and wall switches.
and detailed me on the correct functions
good job fantastic fan........ .....
cheers
2air'
Old 07-12-2006, 09:46 PM   #19
bradk's Avatar
Calgary , Alberta
Images: 14
changed them today
I received my switches from Fantastic Vent today. Inside the package, there was 2 reverse switches and a wiring diagram of both the 6000BTA (airstream stock) and the 6000RBTA (reversible).
I took the front cabin fan apart and had it back together in about 30 minutes.
It works perfectly and really helps the airflow in the trailer. I haven't bothered to install the reverse switch in the rear of the trailer as I don't see us wanting to do anything other than venting out from that area. Pulling in at the front of the cabin, venting out the rear.
The only difficult part only because I had to go onto the roof was re-routing the red motor wire to the reverse switch. Otherwise, very easy and satfisying Twinkering today.
brad.
Old 07-12-2006, 11:11 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by flyfisher
I wonder why Airstream doesn't offer the MaxxAir fans in lieu of Fantastic Fans? It seems to me that they are caught in a time warp with Fantastic Fans.
One of the reasons we added covers to our fans was so we could do exactly what you did at that rest stop. Another reason was to be able to run our fans in the strong afternoon winds that we often experience here in the northwest in the summer that forced us to close the Fantastic Fan for fear the cover would blow off before we added the MaxxAir vent covers -- I know that the wind never blows in Hood River, Or though.
John
Not much wind here in Hood River........'been blowing 20-30 for over a week now. Still waiting for it to get REALLY WINDY!!!
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
