Old 08-13-2018, 10:41 AM   #1
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
Replacing roof vent cover
Gott in Himmel! When we got to the beach and went to open the rear ceiling vent (fan-less) on our 2004 Safari the plastic cover was gone! (And no, we weren't driving with it open.)
Can I replace the plastic portion alone or do I have to get a whole new vent assembly? And how do I know which one to get? There is no maker name on the vent and no paperwork associated with in amongst my volumes of AS-related owners manuals. Any good sources?
(Thank God there's no rain in the immediate forecast.)
StreaminGeo is offline   Reply With Quote
Old 08-13-2018, 11:09 AM   #2
2012 25' FB Flying Cloud
Parker , Colorado
Since yours doesn't have a fan and 2 in a 25fter would be necessary in my opinion, I would replace it as I've done with a MaxAir plus II. It only took about 45 minutes and gives you auto rain closing, reversible, and 10 speeds all controlled from a remote. Under $200.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 08-13-2018, 11:45 AM   #3
2004 25' Safari
Hmmm.... Sounds like a good idea, but wouldn't I have to get electricity to the fan somehow?
Old 08-15-2018, 09:51 AM   #4
2004 25' Safari
Nobody?
Old 08-15-2018, 10:17 AM   #5
Mollysdad's Avatar
I had the same thing happen in my MH. I was brushing my teeth and looked up to see the sky! I never opened those vents.
You can replace just the cover (I'm not talking about Fantastic Fan)
Here's the process:
Remove the trim piece on the inside to access the screen and crank. Disconnect the crank arm from the lid bracket. Then on the roof, the lid is held by a metal extrusion, so just unbend the tab locking the pieces together and slide it out. Replace on new lid and replace the inner workings. Easy-Peasy. You never touch the frame or caulking.
My old ones were translucent and had sat in the Sun for years. I have no idea where it went, probably in Kansas in some cornfield. I bought new smoke tinted ones and they were a direct replacement. About $20 at the time.
Since I had two of these, I replaced both, then kept the good old one for a spare. I had to order them, since I was in Colorado, but I got them in a few days and it didn't rain!
Make sure you get the same one. There are a couple different manufacturers. You'll be able to tell from the crank crossbar.
https://www.etrailer.com/Enclosed-Tr...BV0554-03.html
Old 08-15-2018, 11:10 AM   #6
Parker , Colorado
you are right on needing to pull electricity to it. Maybe try to pull wires from a nearby ceiling light?
Old 08-15-2018, 04:20 PM   #7
2004 25' Safari
Thanks, Mollysdad!
Old 06-19-2019, 10:29 AM   #8
Brunswick , Maine
1961 Ambassador Maine
I am restoring a 1961 Ambassador 26. First project will be to replace the forward and aft roof vents. The forward vent is rectangular. Ive not yet found a rectangular one. Do they exist? I am very new to the process. Thanks Brian.
Amadon is offline   Reply With Quote
Need multiple exterior parts - window, vent cover, A/C cover danheit Airstream Classifieds 1 05-04-2016 12:57 PM
Change a metal roof vent by a transparent roof vent ? Gal Roof Vents, Skylights & Fans 11 12-27-2014 05:55 PM
Replacing "Vent Cover" artemis917 Roof Vents, Skylights & Fans 9 10-23-2009 02:30 PM
roof vent cover kent osborn Roof Vents, Skylights & Fans 1 11-02-2003 07:58 AM
