Old 01-11-2007, 12:24 PM   #1
1971 31' Sovereign
West Monroe , Louisiana
Red face Replace roof vent
I have a 1971 31' AS, the cover for the galley roof vent which measures 14" x 25" has dissappeared. The only replacement I can find is molded plastic cover. I think I might could have a galvanized metal replacement made, so I would still have ventalation, but that could get expensive. Any ideas??????
cr062065 is offline   Reply With Quote
Old 01-11-2007, 12:29 PM   #2
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Have you seen this from VTS? It's lexan not plastic. Should work nicely.
-Tim
theVAP - Airstream Podcast
Old 01-11-2007, 12:46 PM   #3
1971 31' Sovereign
The old cover had two threaded flat metal brackets which held the cover in place and adjusted the vent. This cover looks nice but how does it attach to roof? Thanks for your help
Old 01-11-2007, 01:08 PM   #4
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
On these reproductions, you typically have to resuse your original hardware.
I'm not familar enough with your model, but you could give VTS a call, they'll know.
-Tim
Old 01-11-2007, 01:11 PM   #5
1971 31' Sovereign
I'll do that, Thanks again
Old 06-29-2007, 04:13 PM   #6
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Astradome Cover VTS
Just received my replacement vent cover from VTS. Its the center 14x26 cover above galley. I ordered the model for 1970 and later. Its a perfect fit!!! Yes you do have to use your existing hardware and its a bit pricey at $143.00. Its made of lexian so I think its worth the cost.
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 06-29-2007, 04:47 PM   #7
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
If you
If you can show a picture?
I have several vents available ..
took off my 84 when i had fantastic fans installed..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Repairing roof vent covers? JohnGalt48 Roof Vents, Skylights & Fans 21 04-15-2007 04:45 PM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 05:44 AM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
