Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 11-06-2003, 11:51 AM   #1
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Replace original vent pipe cover?
I am chasing down leaks ... leaks are my life at the moment ...
As part of this effort, I am going to replace the vent pipe gaskets. The question is, should I also replace the vent pipe covers? Mine might be original and they seem OK (intact). They are apparently made of plastic or some type of hard rubber.
Are they likely to fall apart when removed? Is $80 for two new aluminum covers a smart move? Thanks for any thoughts.
-- RL
PS: Picture shows one of the covers. Note that the screen is very high up in the pipe and obviously not intact. You can just barely see the fringes of the screen around the edges of the hole.
rluhr is offline   Reply With Quote
Old 11-06-2003, 11:52 AM   #2
rluhr
Commercial Vendor
rluhr's Avatar
2005 30' Safari
Here's the other one (curbside)
Curbside vent pipe. Plenty o'Vulkem here! From water stains on the inside, it was apparently leaking at one time.
Old 11-06-2003, 03:00 PM   #3
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Vent pipes
I just received my new gaskets and screen to install. From what I understand the screen goes over the pipe first and then the gasket goes over the screen. Directions are on the Inland RV web site.
I have the metal covers but reading other post yours are most likely to brake when removed (plastic).
Garry
Old 11-06-2003, 04:24 PM   #4
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Are those even "originals"?? pretty ugly looking...
well, fwiw: I was going through the "saga of the mystery leak" a few months back, just before you arrived on the scene. I'd seen the many, many admonisions from the many more experienced airstreamers here to check the plumbing vents. And that was on my list of things to do, eventually, but I didn't really think they could possibly be the source of my particular leak; the water was coming in at a point that was higher than the level of the vents, and nowhere near either one of them. I was thinking "air conditioner" or possibly one of the crank-up vents, but after resealing everything possible up there on the roof, the leak still appeared in heavy rain. (didn't happen in light rain, which makes sense now)
I finally ordered the gaskets for the vents from Andy, and I wish I had done it earlier. The existing vent gasket was not keeping any water out of the trailer whatsoever; it was barely even touching the vent pipe. the confusing thing is that the black-tank vent pipe, which is in the rear curbside corner, is plainly visible inside the trailer where it comes in through the roof, and there wasn't a speck of water visible in there. so where did the water go? The theory is that it was absorbed by the insulation, and wicked to all sorts of other invisible places inside the walls and even up into the ceiling. Water was dripping into the interior of the trailer at the seam between the center ceiling panel, and the wall panel, about 10 or 12 feet forward (and uphill) of the vent pipe.
It only happened during heavy rain...because of the vent cover acting like a "leaky bucket". there is a drain hole to let water escape that falls between the cover and the actual vent pipe; the gasket keeps it from coming into the hole in the roof through which the vent pipe passes. if the rain fell at such a rate that it filled this "bucket" up quicker than the drain hole could allow it to escape, the water would rise to a level above the gasket, which wasn't sealed to the pipe anymore, and would then "pour" inside the trailer. (when it wasn't raining hard, the only water that would come in would be those few drops of rain that just happened to fall right on the small gap between the gasket and the pipe...pretty small target).
ANYway...since I replaced the gaskets, it has rained quite heavily a number of times...no more leak. (at least none that I can see
Chuck is online now   Reply With Quote
Old 11-06-2003, 05:49 PM   #5
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Vent covers and their gaskets are at the top of my list on any unit I buy. I did my 76, the 65, and the 78.
The Argosy's needed new covers since they used ABS at the time as a cost savings, the 65 safari I upgraded to newer style. In all cases the gasket for the most part came apart as I tried to remove it, so here in sunny/rainy florida I would have been dealing with buckets of water.
Like Andy says "check those vent gaskets"
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 11-06-2003, 06:53 PM   #6
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
I need to replace too
I'm getting a leak and don't I don't know if my vent gaskets have ever been replaced. If mine are plastic are the odds they'll break when removed. If so I should order them before I start rather than take a chance then not be able to finish the job if they do. Thanks.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 11-23-2003, 02:33 PM   #7
Sneakinup
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
I'm undertaking the replacement of my 2 roof vent gaskets today.
Does anyone have any suggestions for getting the screws out that simply will not turn? The first vent I managed to get most of them out, and the other heads were already for some reason sheared off. Vent number one done!
The second vent... I can't get one out. I have tried drilling off the heads, but they are steel screws and I can't get any leverage to really lay in to them. I've gone through a handful of high speed steel bits already.
Oh, it is obvious that these vent gaskets have NEVER been changed in 30+ years.
Any suggestions would be greaty appreciated. Rain is in the forecast for Tuesday, and I want to see how much of the leaks these stop.
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 11-23-2003, 02:50 PM   #8
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Pick provided good photos and discussed the screen on this thread.
Would grinding the heads off let you remove the vent cap, then have better access to the screw shanks? Anybody -- Sneakinup's question is still open...
Old 11-23-2003, 04:07 PM   #9
Sneakinup
Master Riveter
Sneakinup's Avatar
Images: 72
Thanks for the lead to the post. I searched earlier, but for some reason didn't find it.
Misery loves company. It's good to see that I am not the only one that had trouble with that.
I can't get close enough to grind it off without ruining the vent or my awning cover, so... I am just going to have to hit Home Depot again for a few more fresh bits. I've sharpened them, but still no dice. Ahhh, it's only money.
By the way. I never got any instructions with mine from Inland. I vulkemed underneath the gasket where the vent came through the aluminum, and a shot in the holes. Then I put a fine finger shmearings worth around where the gasket and the vent pipe meet. Then I layed the screen over, put the vent cap on with yet a little more Vulkem, screwed it down and trimmed the excess screen. It's on there tight and added vulkem should keep it dry... I hope.
Tomorrow when I get the other vent cap off I will try that one with the screen under the gasket.
Next project... lifting up my AC and replacing that gasket. I'm not looking forward to that one!
Old 11-23-2003, 05:46 PM   #10
thenewkid64
Just a member
Images: 21
Here is a link to the thread with the instructions for installing the new gaskets.
Of course there is nto additional help for that frozen screw.
Brett G
Old 11-24-2003, 11:00 AM   #11
Sneakinup
Master Riveter
Sneakinup's Avatar
Images: 72
Unbelievable!
Of all the "projects" I have done so far on my trailer, that one @#$@#(* vent was the worst so far.
Last night I had a brainstorm to get a tiny grinding bit for my Rotozip tool. (Someone suggested grinding, but in my head, I was thinking of my 4-1/2" grinder. Duh!) That managed to get the heads down flat. Then I carefully cut away the old gasket and caulking from underneath each screw, and using the a hacksaw blade, slid it under the edge of the vent so I could slide the blade back and forth to at least notch the screw. After that, I used a flat chisel and carefully whacked it until it sheared off. Then I was able to drill out what was left of the screws and reinstall the vent and gasket.
Let it rain!!!!
Old 08-29-2004, 09:48 PM   #12
jdleezer
Lost My Rivets
jdleezer's Avatar
Profile:  1969 27' Overlander
New Braunfels , Texas
Help! Vent Pipe Replacement
I'm in the process of polishing my trailer. As I'm doing this, I'm also attempting to replace the refrigerator vent, stove vent, and the two pipe vent covers. I bought all the above from Inland RV and have discovered none of them fit (match) exactly the plastic ones (probably original) I removed from the trailer. The aluminum vent pipe covers from Inland RV are smaller than the plastic ones I removed. To attach them I am going to have to drill new holes in the trailer. I am leary to do this. How would I fill the original holes (vulkam/rivets) and however I do this wouldn't I always have a potential source for leaks in the future?
Thanks in advance!
John
WBCCI #3162, VAC
1969 Overlander International
"It's the little things in life that...."
jdleezer is offline   Reply With Quote
Old 08-30-2004, 08:40 AM   #13
till
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
I will have four to do my self soon. The old style is larger then the new Inland version, so do I just rivet the old holes shut or fill them with velkum?? I will have the inside skin out so sealing from the inside will be an option.
Tedd Ill
AIR#3788, WBCCI#4028 Membership discontinued
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 08-30-2004, 08:46 AM   #14
rluhr
Commercial Vendor
rluhr's Avatar
2005 30' Safari
Yes, the new kit from Inland will not fit the old rivet holes. Seal the old rivet holes with a dab of Vulkem and a new Olympic rivet.
If the vent sits on top of an old hole, just use a dab of Vulkem. The new vent gasket you bought will do the rest.
No, they won't leak in the future if you seal the holes properly the first time.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
Vent pipe leak - How? TomW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 12-25-2003 10:11 AM
Vent Cover - Lundeen Zed2 Roof Vents, Skylights & Fans 1 10-12-2003 01:44 AM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 01:05 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 06:44 AM
