Old 05-31-2010, 05:09 PM   #1
1964 22' Safari
kootenays , BC
Question replace an old vent with a window
ONe of the vents on my '64 Safari ripped off one day and I would like to replace the hole with a piece of plexiglass or something to create a skylight.
ANy suggestions? how do I properly seal it? How much body weight can the roof hold up with out denting it?
Thanks very much for any info!
fancy pants is offline   Reply With Quote
Old 05-31-2010, 05:18 PM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
What size is the opening. Would a fantastic fan with cover work.
Don
adonh is offline   Reply With Quote
Old 05-31-2010, 05:43 PM   #3
Plexiglass is not intended to be exposed to the sun.
If so, it will crack and craze rather quickly.
Lexan does not have that same problem.
Old 05-31-2010, 06:40 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Fantastic makes an unpowered vent you can install in place of your old vent. They have a smoke colored cover that lets a lot of light in, and it's still functional as a vent, albeit without a fan. Here's a link to an article on how to replace your old one with a Fantastic, you just won't have to wire it:
A Fantastic Story
Old 06-05-2010, 12:27 AM   #5
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Concur with Overlander63, I replaced my original vent (albiet modified at some point by a PO with a piece of fogged-out plexiglas in the center vent cover) with a fantastic vent. They come with a tinted vent cover and a two-way multi-speed fan. Quiet, reliable, good value and the unit lets light in...
Good luck!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
sealing, skylight, vent, window
how to replace a side window on a 2008? Randjg1 Windows & Screens 0 09-15-2009 11:46 AM
Replace roof vent cr062065 Roof Vents, Skylights & Fans 6 06-29-2007 04:47 PM
Replace original vent pipe cover? rluhr Roof Vents, Skylights & Fans 18 08-30-2004 12:12 PM
Replace window screens Marc Windows & Screens 6 08-12-2004 03:35 PM
How do I Replace a Cracked Vent Cover? 66Overlander Roof Vents, Skylights & Fans 5 06-06-2004 05:36 PM
