Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-04-2004, 12:41 AM   #1
silverlassie
silverlassie's Avatar
Profile:
Removing vent screws
The front roof vent cover is attached to brackets that are raised by two screws (see picture if it makes it). I have a new cover that will need the original hardware. The cover is attached to the brackets by poprivets. There is limited room to drill the old rivets out without removing the screws. It appears that the screw could be pushed inward to miss the top vent flange, then lifted out of its hole. I fear damaging something by putiing that pressure on it.
Can anyone tell me the best procedure?
Thanks ahead of time!
Silver Lassie
Mindy WBCCI #5672
silverlassie is offline   Reply With Quote
96 excella vent lid replacement help needed dufrain Roof Vents, Skylights & Fans 0 10-30-2003 01:34 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 01:17 PM
grey water plumbing vent Cruiser Waste Systems, Tanks & Totes 6 07-14-2003 03:03 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
