Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-26-2006, 02:29 AM   #1
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Rear vent - Original??
Hello all -
Have a '92 34' Classic Limited. It has a rear vent that has a full shroud that seems designed for venting at all times including a higway speeds. Will try to post photos but will also try to describe, as my luck posting photos is so far 0%.
The vent cover ( rectangle shape - aprox 15x20) that looks to be factory installed based on roof cover applications and overall fit and finish. It has "AS" on the side. It ( cover) goes to the trailer roof along the front edge and back along the side about 4 or 5inches - perhaps to allow venting at speed. Then it rises to about 4/5 inches height along the rest of the perimeter. There is a fan mounted inside the above mentioned cover, with a round housing, that is exhaust only. There is a wall mounted switch that operates the fan in the rear bedroom. The inside has louvers (2) that are operated manually - there is no weather tight closure ie. there is always a heat/cool air leak here. The inside grill is rivited and attached by screws.
1st question - factory?
2nd question - if not, then who made it since there is no idenitifiable info?
3rd question - should I replace with a FF? Got a FF (from an '00) for $90 complete. Deal? or not a deal?
4th question - Is this a 'do-it-yourself' install?
Thanks to any and all answers to the myriad above.
Axel
SilverToy is offline   Reply With Quote
Old 04-26-2006, 05:37 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
Axel, answering you questions in order:
1-Maybe. Airstream put some (IMHO) cheapie vents like that on their coaches for a while.
2-Sounds like a Maxx-Air. There is another factory vent similar, with a plastic top, and plastic gears to open and close, the gears break frequently, and parts are NLA.
3- I would. $90 is 1/3 to 1/2 price, depending on fan and options.
4-If you pay attention to what you are doing, and are fairly mechanically adept, you should be able to perform this upgrade.
Good luck
overlander63 is online now   Reply With Quote
Old 04-26-2006, 02:22 PM   #3
SilverToy
Maxx-aire sorta...
Terry - Thanks for the reply.
The vent cover is sort of reminiscent to the Maxx-aire cover but the newer MA's go all the way around the lower/roof touching perimeter. This one is NOT like that as it is open on the middle to the rear lower perimeter.
Is installing the FF primarily and outside endeavor - yes?
Spoke today with the guy that will be pulling the FF out of the other trailer and there was some question about the wiring/ rain sensor being affected by the removal. Is there anything to this?
Thanks.
Axel
Old 04-26-2006, 02:24 PM   #4
SilverToy
Fantastic Fan photos
Hello all-
Does anyone have photos of a FF outside a trailer ( either before install or after removal). Any kind of an inventory of all that I should be expecting when I buy this unit from the salvage guy.
Thanks for any and all info. Will check the FF website but it never hurts to ask.
Axel
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 06:35 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 01:05 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 05:23 PM
Restore shine to hood and rear scotta Airstream Motorhome Forums 1 06-28-2002 08:26 AM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 10:00 AM
