Old 03-04-2013, 06:21 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Range Vent question ????
Just the other day I noticed that the exterior of my range vent has two side clips to retain the flapper. I never noticed that before and upon closer inspection and when I unclipped the flap it came off in 2 pieces. So I re-installed it and hooked the retaining clips back to hold it. When I get home I will take it off and make an attempt to repair it so that it will be usable. Our former trailer ( '85) had a hand lever inside the hood to open the vent. Our current trailer does not. It looks to me like you need to undo the retainer to make the vent usable and then re-clip for travel.
Just trying to see if I got it right ????
Thanks all, See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 03-04-2013, 06:49 PM   #2
dznf0g's Avatar
Oswego , Illinois
yes you have it right
-Rich-
Old 03-04-2013, 07:04 PM   #3
retired USA/USAF
2001 30' Excella
Thanks Rich. DUH, when all else fails read the manual so I just found it. Do you have any idea how to access the rear of the control panel. Mine reads full all the time on the waste tank levels. I just read that there is a sensitivity adjustment that can be made from the read which ( I hope ) may correct that but I cannot figure out how to remove the panel face to get to it.
Roger in NJ
TAC - NJ 18
Old 03-04-2013, 07:34 PM   #4
dznf0g's Avatar
Oswego , Illinois
I believe it is glued on and has to be peeled back carefully. There are screws under the plastic film face, I believe.
-Rich-
Old 03-04-2013, 07:40 PM   #5
retired USA/USAF
2001 30' Excella
Thanks, I'll look again. I can slip a thin blade around the edges but can't seem to find a way to release the panel. I'll keep at it, ever so gently
Roger in NJ
TAC - NJ 18
