Old 06-24-2006, 07:42 AM   #1
1985 31' Limited
Ashland , Nebraska
range vent fan
Recently purchased '85, 31' Limited. No owners manual. How do you turn on the fan above the stove. I can open the vent but no switch for the fan. Does it automatically turn on like the roof vents?
jlsmits is offline   Reply With Quote
Old 07-29-2006, 03:53 AM   #2
1973 31' Excella 500
Morristown , Tennessee
Don't know agout that model but two older trailer that I have owned have a lever on the side of the vent housing in the cabinet above the range. One direction closes the vent to keep air out and the other opens it. Push it to it's opening limit turns on the fan.
Joe
Alumin8 is offline   Reply With Quote
Old 07-29-2006, 05:23 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
jlsmits,
The fan should turn on when you open the cover using the lever. It may be a bad or misadjusted switch, or possibly a blown 12v fuse. Do you have anyother 12 volt items not working?
Aaron
WBCCI #XXXX AIR #2495
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
