Old 05-15-2006, 09:17 AM   #1
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Powered vents
Ready to install a Fantastic Fan. Is there a "hot pigtail" already at the opening or do I have to tap the light circuit? 2006 Standard 25' Safari.
Greg
Roadtoaster is offline   Reply With Quote
Old 05-15-2006, 09:20 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I believe that the fan taps off the hot lead from the light. I don't think they have a seperate circuit for the fan. A good place to look would be the owner's manual. They have the circuit diagrams in detail in the manual.
Old 05-15-2006, 10:25 AM   #3
Now why didn't I think of that?
Thaks
Greg
Old 05-15-2006, 10:50 AM   #4
Aluminut
2004 25' Safari
. , Illinois
Only reason I recalled the manual was that I installed a subwoofer in mine over the weekend, and found that the black wire (at least for the pre-wired sub are radio area) was positive, not neg. A few blown fuses later I decided to RTFM and came across the wiring schematics.
Old 05-15-2006, 12:03 PM   #5
2005 22' Interstate
Afton , Virginia
Tks for the info, and now - An Ignorant Question:
I wonder if this means that the Airstream standard wiring is to use the normal AC convention of Black = hot, whether it is DC or AC? And by extension, +12VDC is the accepted "hot" lead. I haven't found much wiring information in the Interstate factory manual, in fact it is a little bit sketchy, with lots of cut and paste from OEM sources.
herrgirdner is offline   Reply With Quote
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 09:37 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Does anyone know #16019? Pahaska Our Community 15 06-30-2002 04:25 PM
