Old 10-04-2011, 06:11 PM   #1
Rivet Master In Training
Kevo's Avatar
1965 22' Safari
Mount Airy , Georgia
Send a message via AIM to Kevo Send a message via MSN to Kevo Send a message via Yahoo to Kevo
Poor Boys Skylight...
Anyone who has replaced one knows they are expensive, and to be honest, even the nice smoked Lexan ones, left me looking for something better. I really like the idea of being able to look up and see the stars at night. So aside from maybe the possibility of too much sun sometimes, anyone see a drawback to my little home made sunroof ?? ( yes i still need to attach it to the lifts...but I ran out of daylight today....
Kevo is offline   Reply With Quote
Old 10-04-2011, 06:16 PM   #2
1994 30' Excella
Mississauga , Ontario
Nice Job.
The only downside I can think of might be water puddling on top and then leaving water marks. Make sure there is good slope for drainage.
Al
Al and Jean
TAC ON-3
Old 10-04-2011, 06:25 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I wonder if it wont result in higher temps inside. I bet you could work out some sort of interior shade though.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-04-2011, 08:21 PM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
That's cool! You could always put a tint on it if you needed too. How'd you cement the edges together?
Marc
Old 10-04-2011, 08:55 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Lexan (polycarbonate) is tougher than plexiglass. If you don't get the UV resistant type it will yellow on you in a couple of years.
Untinted it will make the trailer a little hotter, but you could add some UV film.
Old 10-05-2011, 06:24 AM   #6
Kevo's Avatar
1965 22' Safari
There was a learning curve working with the plexi, even with a offset 60 tooth blade for the table saw, it left the edges too rough to work with, so after the rough cut with the table saw, I had to go back and smooth the edged with a laminate bit on the router. This left the edges very smooth. And ready to glue up, although you don't actually "glue" acrylic, I used the Weld on solvent from Tap Plastics, and it actually melts the acrylic together much like pvc cement melts the pvc. As with most first time projects, it could have turned out better. But i learned how to work with it, and the next one should be a lot nicer. you might find this interesting ...
Old 10-05-2011, 08:06 AM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Nice job!
Ahab is offline   Reply With Quote
Another Maxim Skylight Success Silver Otter Roof Vents, Skylights & Fans 36 08-23-2015 06:06 AM
Re-securing OEM Skylight Cracker Roof 14 07-11-2012 09:07 PM
'68 Ambassador Skylight Options 68ambassador Roof Vents, Skylights & Fans 0 10-03-2011 06:24 PM
International 23' CCD Signature skylight Deston General Repair Forum 0 09-19-2011 10:43 AM
Aftermarket Skylight Install?? Rob&Julie Roof Vents, Skylights & Fans 6 03-22-2011 04:09 PM
