Old 03-19-2019, 02:57 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
one more fantastic fan question
On our 2012 25 ft Flying Cloud I can only raise the FF cover manually to turn the fan on. So I am looking for ideas on what might be wrong and what road I should go down to fix it. If it is the switch how do I get to it to check it out and/or replace it. Also could it be short and if so what do I have to remove to check for it.
thanks
urnmor is offline   Reply With Quote
Old 03-19-2019, 04:20 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Is the knob engaged to the motor
Dept of “OverKill”
Old 03-19-2019, 06:53 PM   #3
2007 22' International CCD
IIRC, on my fantastic fans the knob gets pushed up to engage the vent lift motor, and pulled down to operate manually.
It’s not reachable right now, or I would verify that statement...
Old 03-19-2019, 07:27 PM   #4
urnmor's Avatar
Berlin , Maryland
You are correct the knob has to be engaged with the motor for it to work with the switch. However if it is not engaged you turn it on one will still hear the motor trying to open the FF. That said the motor does not make any sound when it is engaged or not engaged.
Old 03-19-2019, 07:55 PM   #5
Time to break out the multimeter and start figuring out what went out inside the guts of the fan unit.
Old 03-19-2019, 08:28 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
It may be that the worm gear has jumped a tooth or two and the limit switch has not cycled.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-20-2019, 09:19 AM   #7
urnmor's Avatar
Berlin , Maryland
If this was the case would you not still hear the motor trying to engage? I hear nothing when I turn on the switch
Old 03-20-2019, 09:24 AM   #8
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
The newer Fantastic Fans the motors do not require the knob to be engaged to raise or lower the dome. The knob is always engaged and when you open or closed the dome manually you are turning the motor and gears in the motor.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 03-20-2019, 09:37 AM   #9
2016 25' Flying Cloud
Nanoose Bay , British Columbia
I had the same issue. I called Fantastic Fan and they shipped a new motor free and fast. That did the job. Easy swap out.
Gary Nijman
2016 Flying Cloud 25 FB Twin
2018 GMC 3500 Denali Duramax
gnijman is offline   Reply With Quote
Old 03-20-2019, 11:43 AM   #10
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I concur
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 03-20-2019, 02:16 PM   #11
urnmor's Avatar
Berlin , Maryland
Well I went over the electrical connections in the FF. Everything works fine when it is on manual. I can raise the hood, run the fan at variable speeds etc. However I cannot get any power when it is on electrical. I believe a portion of the motherboard has quit. Here are some photos.
Based on my readings the two red wires next to each that are attached to the Motherboard do not appear to be getting any electrical power. They are the wires that run directly to the switch that turns on the motor to raise and lower cover. I am not sure what else to check and as it runs manually is it worth replacing the motherboard or any other part of the fan.
Old 03-20-2019, 02:19 PM   #12
urnmor's Avatar
Berlin , Maryland
ops not sure what happen to the photos will try again
Old 03-20-2019, 02:34 PM   #13
urnmor's Avatar
Berlin , Maryland
Pictures of the motherboard and the knob
don't seem to be able to load photos. I am wondering if they are to big
ID:	336155   Click image for larger version
Old 03-20-2019, 03:43 PM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
There is no limit switch in a fantastic fan....
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Fantastic fan: Lifetime warranty no more. zedex Roof Vents, Skylights & Fans 16 06-09-2014 03:22 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
