Old 07-27-2010, 07:40 AM   #1
1962 24' Tradewind
Berry Creek , California
Nothing but a 14x25 hole in the roof
My 62 Tradewind came with a 14x25 hole in the roof covered with leaking plexiglass. I want to put a vent in and it looks like Inland RV is the only provider of domes that fit this size. What do I do for opening/closing the vent? There are no cranks or old-fashioned openers, and no mounting hardware ....there's just a rectangular opening. I really don't want to put in a hinge. It looks like Inland has the old hehr? openers, but I don't see how to attach them to the vent frame in the trailer. Any suggestions?
nmeyer is offline   Reply With Quote
Old 07-27-2010, 07:45 AM   #2
Is there a "U" shaped bracket at each end of the astrodome frame?
Can you post a photo?
Some of the vent operator brackets are probably still around, but used.
Old 07-27-2010, 07:55 AM   #3
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
i had to put in a skylight. $85 or so?
RV Skylight
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 07-27-2010, 08:09 AM   #4
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Your photo shows the mounting brackets for the Hehr vent operators. It appears that all you are missing are the hinged pieces that should come on the new operators that mount to the vent lid. If the new operators work like the old ones, they will snap into place into the brackets that are shown in your photo on each short end of the vent opening. I will see if I can photo the complete assembly later this week when I have the trailer at the house. You have the same set up that we do on our 62 Ambassador.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 07-27-2010, 08:46 AM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Here's a picture of my skylight showing the original lifters in the extended position and the Lexan cover I made. Hopefully this will give you an idea of how it all mounts up to the roof. You are also missing the angle aluminum trim that goes around the ceiling opening.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-27-2010, 09:05 PM   #6
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
That is what mine looks like,... Thanks Brad for posting!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 07-29-2010, 08:39 AM   #7
1962 24' Tradewind
While the bracket holders are in place, both of the little round bases that sit in the brackets to hold the HEHR openers are missing. Does anyone have the holders (or brackets and holders) that I need in so that I can get the HEHR openers to stay in place? I called Inland RV this morning and they did not have the holders that fit into the brackets. If I just get the HEHR openers as shown in the Inland catalog, there's nothing to hold them in place to the trailer... two forks of aluminum won't hold a round cylinder of aluminum very well in a moving or stationary trailer This is hard to describe... hopefully the pictures help as I do have two HEHR openers and complete brackets/holders on a vent further back in the trailer to help show how the HEHR openers sit in the little round base that attaches to the bracket.
ID:	107720   Click image for larger version
Old 07-29-2010, 09:12 AM   #8
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I'm not sure you understand so I'll just ask. In your left photo, the black piece with the four sided extension is part of the lifter mechanism itself. That is what attaches the lifter to the bracket. To get this off the bracket, just put a flathead screwdriver in between the lifter and the bracket and it will pry off easily. Once you get this off, you'll see how it all works providing that your lifters aren't stuck. If so, you can soak them in WD40 or another solution for a couple of days and they should loosen up.
FF
Old 07-29-2010, 09:42 AM   #9
You DO NOT need that "round" part.
The operators are designed to pop into the bracket, that will hold it in place.
Old 09-19-2010, 10:11 AM   #10
1962 24' Tradewind
The new vent lifts work great, I got a couple more for the old back vent, too (before/after): http://www.airforums.com/forums/f455...tml#post897258
Old 04-20-2015, 03:39 PM   #11
Boxcardawg's Avatar
1964 22' Safari
San Diego , California
Thumbs up Boxcardawg
Thanks to all - I just R & R'd my 14 X 25 roof vent from this discussion - Popped out and cleaned both risers and now they both work as they should!
Mike
San Diego/Tijuana
Boxcardawg is offline   Reply With Quote
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
cutting 14 x 14 hole in roof mwillis1970 Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-04-2005 09:36 AM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
