Old 11-09-2015, 05:08 PM   #15
NC Camper's Avatar
2018 27' Globetrotter
Greensboro , North Carolina
Originally Posted by switz View Post
That is why we switched the two stock Fantastic fans out for the Maxxfan model 7000K on the 201523D. Plus no shroud is needed to keep the rain out like on the Fantastic fans. We will replace the Fantastic fan in the Classic in the spring with a 7000K Maxxfan and get also get rid of the Fantastic fan shroud.
switz, do you find that there is as much light with the Maxxfan as the Fantastic fan. I have been planning on changing out one fan in a new 25 FC because the AS comes with single direction fans. I have really liked what I have seen on the Maxxfan and if I'm going to change one out I might as well get one that meets all my needs. Thanks.
NC Camper is offline   Reply With Quote
Old 11-09-2015, 06:28 PM   #16
time2play's Avatar
2013 30' Classic
Kent , Washington
Here is my Fantastic fan "cheat sheet" which I wrote for my own sanity. I was always confused by the fan settings so I wrote my own step-by-step instructions. I'm attaching the PDF file, hope this helps.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 11-09-2015, 06:39 PM   #17
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I gotta agree, the fantastic fans are not the easiest things ever, but usually I can get them to work. It does get frustrating at times though...especially when the fan thinks it's wet but you really want it on.
Mike
Caffeinated is offline   Reply With Quote
Old 11-09-2015, 07:46 PM   #18
2015 28' International
Aloha , Oregon
Thanks Yolanda for the cheat sheet - that's helpful.
You might update it for manual operation. Sometime we want to just crack it a bit by cranking the knob, to keep the place from condensing up at night while sleeping. We found the power switch opens it all the way or nothing (unless we're using it wrong.. which is entirely possible).. :-)
garybair is offline   Reply With Quote
Old 11-09-2015, 09:03 PM   #19
time2play's Avatar
2013 30' Classic
Kent , Washington
Good point Gary! Thanks, I'll add that in (once I figure it out).
Yolanda (and Phil)
WBCCI #7878
Old 11-09-2015, 10:25 PM   #20
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Originally Posted by interstateflyer View Post
In 2013 the Fantastic Fan had a lid crank with a clutch so that you could just pull down the knob and turn to open.
In 2014 they changed to a crank that requires you to turn the gears while you turn the crank knob. The tech at Fantastic Fan doesn't know the reason for the change but told me that it's ok to turn the gears with the knob.
We have a 2014 and to manually open the FF you still pull the knob. Auto opening and closing is with the knob pushed up. Ours originally only vented out, but I called FF and got the schematics and switches and easily turned them both into intake and exhaust units.
George
gandttimes is offline   Reply With Quote
Old 11-10-2015, 04:04 PM   #21
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We have the Fantastic shroud over the Fantastic fan on the Classic. The two white 7000K Maxxfans on the 23D seem to let in the same amount of light.
We did put the frosted white Maxim skylight in the 23D and over the bathroom in the Classic. That model amplifies the the light while reducing heat gain/loss. The front Maxim in the Classic has the bonze lense. It is light an airy inside both units.
I like the simpler control panel of the Maxxfan as does my wife. The remote is nice as well.
Old 11-11-2015, 10:08 AM   #22
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I'm in my 2015 now. Honestly, the knob/handle can be turned but you can't pull down on it, just turn it and the motor I guess. The fan direction does not seem reversible.
My quick start is thermostat to cold, speed at 1, fan to on and flip the open/close thing. If that doesn't work, try again. Shheesh.
Then, play with the buttons. To stop it from opening all the way, turn fan speed to 0 along the way.
DoublTrouble is offline   Reply With Quote
Old 11-11-2015, 07:34 PM   #23
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
DoublTrouble. When I was having some issues and questions about FF I called them and found them to be extremely helpful. Give them a call.
George
Old 11-15-2016, 12:03 AM   #24
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
From the picture you have an automatic opening FF. There is a small black switch when pushed begins opening the fan hood and turns on the fan "if" you have the thermostat turned down to the cool side. Pulling down on the knob disengages the motor from the hood. Rotating the knob while disengaged lowers or opens the vent hood. Select fan speeds 1,2,3....0 stops fan. Neat feature vent hood closes automatically if rained on. Will open again when dry. Good luck hope this helps
zapper is offline   Reply With Quote
Old 11-16-2016, 01:48 AM   #25
switz's Avatar
2014 31' Classic
Images: 8
The newer Fantastic fans built by the new Fantastic fan business owner have removed the free wheeling "clutch" of pulling the knob down to save a few pennies on each unit. That was apparent in the 2015 models. Our 2014 Classic (built in January 2014) had the "clutch" and the 2015 23D International Serenity built in September 2014 lacked the "clutch".
We solved the issues in both of our trailers we had with the ugly rain shroud of the Fantastic Fan on the Classic and "clutch" issues in the 2015 model by replacing them with the MaxxFan 7000K fans that have a low profile when the lid is closed, ten fans pads and reversible along with temperature seeing operation all controlled with a remote. That process also got rid of the potential water leaks that would be caused by the cracks in the Fantastic fan mounting plates caused by over tightened fasteners at the factory.
Old 03-02-2017, 11:41 PM   #26
zapper's Avatar
But does anyone know what that little red light in the fan does?
Old 03-03-2017, 03:21 PM   #27
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
So, we have a 2015 FC23FB. Power switch turns the fan on and off. Dial gets you some temp control, but ramp it open to keep the fans running. The lid raise button fails to open the lid if rain or dew shuts it down. That may be part of your problem. We use the manual knob to raise the lid if the electric switch is not responding.
Now, it took a few trips to decide get the Fantastic Fan hoods installed. They should be standard OEM. Shame on you AS. My brothers SOB has them. Either install the hoods or upgrade to the Maxfan that Switz is raving about.
The 23 does not have a two direction fan switch on the 15. You can install the one that Fantastic Fan used until AS value engineered the OEM units and changed to an exhaust only switch. It's on my todo list. If you do not have a window or door open, one vent must be shut down to provide makeup air for the coach. Guess what happens if it is raining.
So, you have our condolences. Sweety learned how to operate them this year, but it took some parctice. At least you have an AS smile to offset the fan deal.
Now that heat/AC control is something else. I really believe the little wee people have cast a spell on these electronic wonders to get even for us not leaving an adult beverage under the coach for them. Pat
PKI is online now   Reply With Quote
Old 03-03-2017, 03:25 PM   #28
PKI
PKI's Avatar
Last time Sweety asked, I told her it shows the power is on. Pat
brakes dragging? can't figure it out katzklaw Brakes & Brake Controllers 7 09-16-2010 06:52 PM
Can anyone figure out what happened here? Caryl Awnings 16 10-22-2009 07:28 AM
Can't figure out how to... 3streams Community Polls 2 10-02-2009 03:04 PM
Can't figure this out streamdreame Steps 6 04-09-2009 01:32 PM
How can I figure out the towing capacity of my 300TE? davida Tow Vehicles 5 06-05-2006 05:07 AM
