Old 12-21-2007, 08:16 PM   #1
1970 31' Sovereign
Collierville , Tennessee
New Fantastic Fan Vintage (pics)
I found a nice fantastic fan on here from Vintage Trailer. Here are the pics.
It will be a couple weeks before I can put it in but I'll take more pics.
TN-TUNDRA is offline   Reply With Quote
Old 12-22-2007, 04:56 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Great! Uh, don't do like I did, and throw that big square piece of foam away. That's the mounting gasket, and I had to dumpster-dive for it...
Old 12-22-2007, 06:35 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
and be aware that that foam gasket is open-cell, so you have to Vulkem from the shell to the plastic edge of the fan body or you'll have a leak. Also, you need to put a dab of Vulkem on each of the zillion screw heads or they will definitely leak, too. I've done that test twice and discovered the same answer both times.
Zep
Old 12-22-2007, 09:18 AM   #4
1970 31' Sovereign
Thanks for the tips. I thought the seal was just packing material. I read somewhere to not use the gasket but just the Vulkem. What would you recommend?
Old 12-22-2007, 10:20 AM   #5
1975 31' Sovereign
1977 23' Safari
On the curved roof, the gasket helps reduce the stress on the plastic mounting flange of the fan. As a matter of fact, I cut strips out of the center piece of the gasket and lay a double layer along the outer edges (the edges parallel with the sides) to further reduce the bending stress. I don't cinch the screws down too tight on those two edges. You get the drift.
It does take a little more Vulkem, but I think it's an improved installation method.
Zep
Old 12-22-2007, 10:32 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Tundra - Is that a Fan-Tastic Vent? Is it made by the same folks that make Fantastic Fans? Don't forget to post a few photos of the swap out. My 75 has massive light fixtures at the vents and I am not sure how I would adapt something like that.
Richard
Old 12-22-2007, 11:43 AM   #7
1970 31' Sovereign
It is a Fan-Tastic Vent/fan 5000. Vintagetrailer.com has them "special" made in gray to match the AS. The stock ones are white on the top of the vent. I'll take some pics of the install might be a week or 2 with X-Mas next week. I think your fixtures have the lights and vent in the same fixture. I think you would lose the lights unless you could rigg up something.
Old 12-22-2007, 03:39 PM   #8
Images: 14
Fantastic-Hehr
Here's how I modified this flat Fantastic Fan so as to preserve the Hehr vent look.
ID:	51337   Click image for larger version
bjond is offline   Reply With Quote
Old 12-22-2007, 03:49 PM   #9
1975 31' Sovereign
1977 23' Safari
Herb, is that an original metal vent lid glued on top of the Fantastic Fan lid?
Zep
Old 12-22-2007, 03:55 PM   #10
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Yeah, what Zep asked........
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 12-22-2007, 04:57 PM   #11
igor's Avatar
1972 25' Tradewind
Redmond , Oregon
I replaced all three of my vents a couple of years ago with fantastic vents. Absolutely the best thing I have ever done to the trailer. At first I was a little uneasy about taking tin snips to the inner and outer skins of the trailer inorder for the new vent to fit, but I got used ot it quickly. I will try to post some pics in the morning - my camera is at work I will bring it home in the morning.
igor is offline   Reply With Quote
Old 12-22-2007, 05:28 PM   #12
Images: 14
Fantastic - Hehr
Yes , both the inside and outside are the original Hehr vent cover. The outside fits perfectly. The inside has to be cut in 3 place to accomodate the Fantastic cutoff switch, the crank track and a guide peg molded in the cover.
Old 12-22-2007, 08:50 PM   #13
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
vents
Hey Herb That looks Fantastic. But really, I think I need to do this and have read your article in the Vinatge Advantage a while back. I have to say it was hard to follow for me maybe since I did not have the parts in hand to look at.
Is it possible to show more step by step here and I also promise to go back and reread the article in VA.
Thanks, Gary
The Vintagetrailer gray plastic look good too..........but if we reuse the meal I can polish more!
safari62 is offline   Reply With Quote
Old 11-22-2012, 09:13 AM   #14
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Lid swap
Ref. post #8
Some where in the Forums is a short photo coverage on this use of a modified Fan lid to use the original aluminum one. Can someone guide me to it?
Fantastic fan altamont 2007 Safari SE 12 01-23-2007 09:06 PM
Fantastic Fan Lee Pace Roof Vents, Skylights & Fans 33 04-27-2006 01:39 PM
Fantastic Fan Devoman Roof Vents, Skylights & Fans 35 09-19-2005 07:39 PM
Fantastic Fan mopar7 2003 Safari 14 10-31-2003 06:21 PM
Fantastic Fan jalewis Roof Vents, Skylights & Fans 1 09-29-2003 06:16 AM
