Old 11-22-2012, 09:24 AM   #15
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Glad this thread was just revived. I finished installing a new Fantastic fan yesterday and was just about to add the Hehr lid to the ever growing pile of original but replaced parts in the old barn when I saw this. I may have to rethink using the aluminum lid vs. the gray transparent lid I have for the Fantastic fan. I too am interested in how bjond made the remodel.
Helps?
goshawks00 is offline   Reply With Quote
Old 11-22-2012, 04:19 PM   #16
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
bump
Old 11-22-2012, 05:28 PM   #17
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
The article was in a past Vintage Advantage, if you don't have a copy and are a VAC member, email Tim K for the article.
Bill
Originally Posted by Melody Ranch View Post
Ref. post #8
Some where in the Forums is a short photo coverage on this use of a modified Fan lid to use the original aluminum one. Can someone guide me to it?
Just my personal opinion
Old 11-22-2012, 06:01 PM   #18
pbearsailor's Avatar
Port Hadlock , Washington
Ref. post #8
Found it: Fantastic Hehr Vent- How To - Photo Gallery
Some pics in my thread, too. Somewhere
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 11-22-2012, 07:14 PM   #19
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
-steve
I just glued the original to the FF lid.
FC7039 is offline   Reply With Quote
Old 11-22-2012, 09:31 PM   #20
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
OK!! Thanks to all...specially Steve for the article. I get my fan tomorrow and will document the swap out....with pictures.
Old 11-23-2012, 01:41 PM   #21
FC7039's Avatar
Allen , Texas
I went out to take a picture of my vent and noticed a corner high. The glue is not bonding to the aluminum. I used Gorilla glue.
I am now more interested in how you are doing it.
Old 11-23-2012, 03:46 PM   #22
You take the original and drill out the rivets, separating the two pieces, and then sandwich the plastic cover in between, either riveting or machine screws to put it back together. If I remember correctly, the inside piece has to be modded just a bit for the lifting hardware. Easy project.
-steve
Old 11-23-2012, 04:59 PM   #23
FC7039's Avatar
Allen , Texas
-steve
My hope was to not poke any holes in the FF lid. Holes leak.
I looked at it more. My FF lid is not flat but rises ever so slight to a peak in the center.
The hinge is held on to the lid by 4 rivets. The lifting bracket is screwed into tabs molded into the lid. I think I may drill the 4 rivets out for the hinge, and fabricate two tabs for the bracket that I can mount to the inner panel of the original vent lid and mount the hinge directly to the original vent lid.
I got a couple more days in this holiday weekend to give it a try.
Old 11-23-2012, 05:28 PM   #24
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
up date
I got the process in motion today.
1....the original with the rivets drilled out.
2....I used Citrus Strip. It took three applications and 3M pads to scrub clean'
3....this is the original vent.
4....just to remind you of planning for the future
Name:	vent fan Hehr apart.jpg
ID:	173149   Click image for larger version
Name:	vent fan Hehr stripping.jpg
Name:	vent fan original Hehr 3.jpg
ID:	173151   Click image for larger version
Name:	vent fan ac drain.jpg
Old 11-23-2012, 05:38 PM   #25
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
up date part two (pictures)
Some progress pictures. Taking a break now will install and final polish tomorrow.
Name:	vent fan Hehr ist polish.jpg
ID:	173154   Click image for larger version
Name:	vent fan Hehr polish.jpg
Name:	vent fan polishing.jpg
ID:	173157   Click image for larger version
Name:	vent fan Hehr compounding.jpg
Old 11-25-2012, 12:46 PM   #26
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Got it done
It could have been done sooner ....but, I had to be sure the Vulkem, used to old the lid to the Fan, was cured. The only hic up was the attach screw hole on the hinge side. The lid is "almost" in the way of drilling and screwing tight.
Name:	Vent anf fan clearance check opening.jpg
ID:	173279   Click image for larger version
Name:	Vent Fan fit.jpg
Name:	Vent Fantastic Fan Vulkem on Hehr cover.jpg
ID:	173281   Click image for larger version
Name:	vent with Hehr cover.jpg
Old 11-25-2012, 12:51 PM   #27
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
more pics
just different angles. By the way I use lots of Vulkem 635
Name:	Vent fit check with chimney.jpg
ID:	173283   Click image for larger version
Name:	vent in place for fit..note lid blocks screw holes.jpg
Name:	Vent Fantastic Fan Vulkem  cover clamps.jpg
ID:	173285   Click image for larger version
Name:	Vent and Fan from above.jpg
Old 11-25-2012, 02:56 PM   #28
FC7039's Avatar
Allen , Texas
How is the old lid connected to the FF lid? Are the clamps for glue?
Fantastic fan altamont 2007 Safari SE 12 01-23-2007 09:06 PM
Fantastic Fan Lee Pace Roof Vents, Skylights & Fans 33 04-27-2006 01:39 PM
Fantastic Fan Devoman Roof Vents, Skylights & Fans 35 09-19-2005 07:39 PM
Fantastic Fan mopar7 2003 Safari 14 10-31-2003 06:21 PM
Fantastic Fan jalewis Roof Vents, Skylights & Fans 1 09-29-2003 06:16 AM
