Old 06-15-2016, 01:21 PM   #1
AF & RN
jgoss's Avatar
2016 30' International
2011 27' FB Flying Cloud
Sherwood , Arkansas
Maxxair Vent Cover for Fantastic Fan
Hi Folks! I know I'll get a lot of responses on this post. I've seen and read the same post several times, but a lot are older postings. Ok, we just bought a new 2016 International 30ft which has one Fantastic fan (due to the dual ACs/50amp). 1. Does anyone know which Maxxair model best fits the new models and allows for maximum opening of the Fantastic vent cover? 2. I believe it takes 4 screws drilled into the Fantastic vent cover mount (not the roof)? 3. Is it OK for me to climb on the roof myself to install?
Thanks in advance!
jgoss is offline   Reply With Quote
Old 06-15-2016, 02:18 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have the standard Maxxair on the rear and the Maxxair II on the front. I do not think opening 1 inch or less makes a bit of difference as far as a normal person would be able to tell. Unless you have calibrated laboratory instruments available.
Yes, 4 screws to mount. You can pre download the mounting instructions from the Maxxair web site.
Yes, climb away. Stay on the ribs and totally off the end caps.
MICHAEL
Old 06-16-2016, 07:42 AM   #3
AF & RN
jgoss's Avatar
Sherwood , Arkansas
What is this tool for? My last AS did not have one, but my new AS does...
Thx,
Old 06-16-2016, 07:48 AM   #4
AWCHIEF's Avatar
Images: 33
I also have one of those mystery tools. When I ask someone said it had something to do with the sink fixture. I never found anything it seemed to fit.
MICHAEL
Old 06-16-2016, 09:17 AM   #5
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
Thanks in advance!
Fantastics response has always been "no covers!" I have owned many different RV's with Fantastic vents and I have never used a cover nor had a problem. If you have a rain sensor, what's the need? And I think that they are all ugly, especially when they get dirt and discolored.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 06-16-2016, 10:03 AM   #6
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
It's OK to get up on roof just stay on ribs. I added the Fantastic Fan specific covers and they requires no drilling, just replaced existing screw with clips and pins allowing for easy removal for cleaning. I love them as it allows me to drive with vents open keeping the inside a little cooler and also open in rain. I am sure the Maxxair models work as well. I know the FF Covers does allow the vents to open fully. Not sure on the Maxxair.
Oh, put plenty of padding around ladder when leaning it up against your trailer.
Chuck
silverlabs is offline   Reply With Quote
Old 06-16-2016, 10:09 AM   #7
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Fantastic makes a cover, and I would recommend you use it. They are called Ultra Breeze, and come in Black, Smoke, and White.
http://www.fantasticvent.com/fan-tas...ml#ultrabreeze
This video kinda explains why.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 06-16-2016, 10:29 AM   #8
silverlabs's Avatar
Waxahachie , Texas
Thanks Damonbeals. Couldn't remember the name of the Fantastic Fan cover. Ultra Breeze, we love them.
Chuck
Old 06-16-2016, 10:34 AM   #9
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
Because the cover closes at the slightest drizzle- even dew will close it. Then you have no ventilation.
I changed out my FFs for MaxxAir fans and couldn't be happier.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 06-16-2016, 11:47 AM   #10
2018 25' Flying Cloud
Roseville , California
Vent covers
I don't yet have my AS, but I recently added two vent covers over my Fantastic Fans on my FunFinder. Fantastic Fan has their own model (Ultra Breeze) that has much greater airflow than the others. I bought mine from Camping World which got me $16 (per fan/vent) installation, so not worth my time installing them, although they do attach easaily using the existing mounting screws for the Fantastic Fan itself. The parts guy at CW told me that the Ultra Breeze is the only cover that won't burn out your fan motor from too much airflow resistance. I'm extremely happy with my setup!
Larry
graywhale is offline   Reply With Quote
Old 06-16-2016, 12:24 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Pick the one you like, they are one of the best improvements you can do to your Airstream; ventilation rain or shine or going down the road. Never a concern the rain sensor system will fail (which they do).
We have the MaxxAir in back and MaxxAir II on front because we think it's the best looking. Although it will slightly keep the lid from topping out, it will provide as much or more airflow as any.
Very easy to install, you can do it from a ladder on the side, no need to go on the roof.
Doug and Cheryl
Old 06-16-2016, 12:52 PM   #12
2012 30' International
Livingston , Texas
Faucet Mounting Tool
Thx,
That looks like the tool that is used to secure the faucet nuts to the studs of the faucet. Look under the sink and see if you would need a deep socket type tool to remove the faucet. It could be a priceless tool if you need one.
glenrms is offline   Reply With Quote
Old 06-16-2016, 04:08 PM   #13
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
one reason some of use covers is the standard fan lid doesn't hold well during heavy hail storms, also the covers protect the lids from UV rays during the summer, around here it can get over 110 for weeks which really hurts thinner plastic and I really like having the vents open even during a heavy rain storm
PeterKV is offline   Reply With Quote
Old 06-16-2016, 06:48 PM   #14
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
When you need to use a ladder against your trailer, try using a 2" swimming noodle. Cut a 12 to 15" length over the part of the ladder against the trailer. You may need to notch out part of the noodle, for the foot rails. This method will prevent creases and dents.
hugheym is offline   Reply With Quote
Maxxair Vent cover install on OEM vent perryg114 Roof 1 08-29-2015 09:19 AM
Maxxair Standard Cover Over Fantastic Fan Cannonball Roof Vents, Skylights & Fans 32 06-04-2015 08:17 AM
MaxxAir Vent Cover for 2014 Sport 22FB Cannonball Roof Vents, Skylights & Fans 2 03-13-2014 12:04 AM
MaxxAir Vent Cover ... color? Soyboy Roof Vents, Skylights & Fans 26 03-26-2011 03:43 PM
MaxxAir II Vent Cover over Fantastic Fan successful installation longdog Roof Vents, Skylights & Fans 2 12-02-2009 07:01 AM
