Old 08-20-2014, 11:31 AM   #1
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Maxxair Standard Cover Over Fantastic Fan
OK, so we get the 2014 Sport 22 FB. It came standard with the base model Fantastic Fan, 3 speed, only blows out (not reversible). I purchased and installed a standard Maxxair cover over the vent. I made this choice due in part to the proximity of the vent cover to the TV antenna when the antenna is folded down. It is a close fit.
We usually run the fan on the lowest speed. I just do not see the issue with "reduced air flow" with using the standard cover on the Fantastic Fan. The fan does not sound like it is laboring any more than without the cover, and the airflow seems fine, even on higher speeds. I think this may be due in part to the fact that the install using the Maxxair brackets leaves the cover above the roof of the trailer just a bit. It does not sit flush against the roof. The instructions even mention this is to allow any condensation to escape out. The end result is that when the fan is on, air is blown out the actual vent louvers of the cover, as well as all around the base of the cover.
I just do not see the issue as discussed elsewhere on the Forum.
Cannonball is offline   Reply With Quote
Old 08-20-2014, 11:45 AM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . .the Fantastic Fan instruction sheet included in my AS manual /book says not recommended. "Never place a Maxx-Air style cover over ceiling fan. Greatly reduced airflow, increased sound levels, & electronic component failure will occur (WILL not might !) un-quote. I too think that's odd, cause you sure see a lot of them on Airstreams ! regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-20-2014, 12:14 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think they ate just protecting their brand.
2012 Dodge Durango Hemi/AWD
Old 08-20-2014, 12:19 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
They just want us to buy their cover. It is all about marketing.
MICHAEL
Old 08-20-2014, 12:32 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
There is a little more to it.
I bought a Maxxair cover thinking what you said is true. I took it back after I found that the Maxxair cover does not allow the lid of a Fantastic fan to open fully. The Fantastic Ultrabreeze cover does cost more, but it is molded so that the Fantastic fan lid fits exactly into it, allowing the lid to open normally.
I think a mechanical failure eventually will occur in the automatic lift arm or its motor if a Fantastic fan is covered by any vent that stops the lid from opening fully.
Alan
Old 08-20-2014, 01:17 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use the MaxxAir II cover with its wrap-around grill design, very large opening. I think it may give better ventilation than any of the others and may be more effective regardless of wind direction. But it's most likely six of one and half dozen of the other.
No water enters even in blowing rain so the vent stays open all the time, never worry about it. That's the best part.
Doug and Cheryl
Old 08-20-2014, 01:37 PM   #7
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We had a MaxxAir cover on our 2005 for 7 years with no problems. We put one on the trailer we have now. I guess we shall see if we have problems or not.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-20-2014, 01:37 PM   #8
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I was not completely clear. Our fan is the base model and does not have the auto open feature, or the rain sensor. You just crank it open manually. I would agree that it might be a problem if the cover blocked the auto-open feature.
I think it is marketing also. I am going to go with it "as is" and see if that "electronic component failure" occurs. If so, I am just out a couple of bucks. BTW, the standard cover integrates well with the 22' Airstream. It looks good from the outside, and provides some light blocking inside. I think that the larger covers might be a bit out of proportion.
I don't know what I am concerned about. I live in S. Texas and will run the A/C 10 months out of the year.
Old 08-20-2014, 01:53 PM   #9
2005 19' Safari
GLENDALE , AZ
Demo of "Ultra Breeze" vent cover, versus other brands:
Old 08-20-2014, 02:33 PM   #10
Wayne&Sam's Avatar
Images: 21
The powered fantastic opener stops when it meets resistance. That can be the end of the travel on the mechanism, a MaxxAir cover, or even grabbing the knob on the fan.
Old 08-20-2014, 02:53 PM   #11
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I have watched that video before. My question is that in this video, they put the Maxxair type vent covers over the fan and flush to the mounting surface. That is not the way a Maxxair cover is installed. They are installed on offset "L" brackets that are mounted to the sides of the vent fan frame. When the cover is then bolted to the brackets, there is a gap of perhaps 1/8" to 1/4" between the bottom edge of the cover and the actual roof, depending on the curve of the roof. That gap has to allow for more airflow. When the fan is running, you can feel air being expelled all around the edges of the cover. The install instructions say this gap is designed this way to allow condensation to escape from under the vent. Makes sense.
I am going to conclude that this is a non-issue for me, and worry about something more substantive, like meteor strikes on my endcaps. It seems that the worst case scenario is that I burn up a fan that is available at Camping World for $145.00. I can live with that.
Old 08-20-2014, 04:18 PM   #12
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Does the maxxair II cover or the ultra breeze increase fan noise?
Cochese is offline   Reply With Quote
Old 08-20-2014, 04:51 PM   #13
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Thanks for this Phoenix I would not have believed it unless I saw it myself. Well done!
Now I just need to figure out were to by a couple of these for my trailer
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-20-2014, 04:55 PM   #14
Arcticfox's Avatar
Central , Canada
By the way does anyone have images of how either if these covers look on an AS?
I'm heading south to the balloon fiesta in a few weeks and might try to get something installed while I'm down there. Are they complicated to install or should one leave it to a dealer ?
TKS
Doug
Standard or Non-Standard Roof Vent and Skylight man7sell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-24-2018 03:38 PM
Ugly!? interior of maxxair and fantastic fans CA_Tallguy Roof Vents, Skylights & Fans 17 07-25-2013 11:28 PM
Fantastic Fans & MaxxAir Best Deals VeggieBullet Roof Vents, Skylights & Fans 15 07-07-2013 09:06 PM
MaxxAir Vent Cover ... color? Soyboy Roof Vents, Skylights & Fans 26 03-26-2011 04:43 PM
MaxxAir II Vent Cover over Fantastic Fan successful installation longdog Roof Vents, Skylights & Fans 2 12-02-2009 08:01 AM
