Old 04-01-2007, 08:37 PM   #1
2007 27' Safari FB SE
McKinney , Texas
MAXX Air Model 900
Has anyone installed one of these on an Airstream? I would like to add them to my new trailer and didn'e know if there was special model or something I should look at. We have a regular vent in the front of the trailer and a thermostatically controlled fantastic fan in the Galley.
Any Help is appreciated.
Krazyjohnny is offline   Reply With Quote
Old 04-02-2007, 08:56 PM   #2
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Bump. . .I'm bumping this to bring it to the top of the list in case someone on the forum has some suggestions in response to his question. Usually someone on the forum has had a similar issue or can pitch in with some help. Hoping you hear soon. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 04-02-2007, 11:31 PM   #3
potatoes's Avatar
I just had two installed last week. The fit and finish is great as well as the operation. I haven't had time to fully run them and use the options but I did do a lot of research and especially liked the low profile. I also went with a low profile Carrier Air V at the same time.
potatoes is offline   Reply With Quote
Old 04-03-2007, 06:53 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
I have 2 MaxxAir fans in my CCD. They work great for ventilitation....even in the rain! Super with one pulling in fresh air and the other venting out the exhaust!
The new model, although pricey, has a remote thermostatic control too.....
Old 04-03-2007, 05:03 PM   #5
jhart657's Avatar
2007 25' Classic
1993 21' Sovereign
Elm Grove , Wisconsin
Thumbs up MaxxFan good choice!
Another vote for MaxxFan! We installed a MaxxFan 2 years ago in our 21ft. Sovereign and couldn't be more pleased. This unit allows for ventilation regardless of weather. We have had the unit functioning while towing in driving rain. No leakage problems! This is a great benefit to us because our cat prefers to travel in the Airstream rather than being confined to our much less spacious truck. Also, when we go hiking or biking we can leave our feline in the coach and not have to worry about a freak rainstorm closing a rain sensor controlled vent. It's one of the best upgrades we've done on our Airstream! Juergen
jhart657 is offline   Reply With Quote
Old 04-03-2007, 07:45 PM   #6
McKinney , Texas
Here is the link to the vent cover I am talking about. It is a MAxx Air Fan Mate 900. I have a great fan already installed in the galley area that is thermostatically controlled and has a rain sensor.(it just closes too slow) and I have just a vent in the front bedroom. I thought this would be a great idea so we can keep the vents open while we are away during the day. Is this the style that everyone has used on their trailer?
Fan/Mate
Old 04-05-2007, 08:17 PM   #7
McKinney , Texas
Thumbs up order is on the way
Well I ordered the two Fan Mate 900s today and they should be here next week some time. I'll try to take some pics of the install.
Old 04-05-2007, 08:40 PM   #8
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
I put a couple Model 800's on our trailer last year. I thought the lighter color would be a bit cooler in hot sunlight than the black ones.
I'm really glad to have gotten them. It's nice to be able to keep the vents open in inclement weather.
The only thing I learned after I put them on was that the factory had put so much sealant around my front Fantastic fan vent that the Maxx-Air cover doesn't fit as close to the roof as it should and we can get some rain under it if the vent cover is opened too high. I guess I could take it off and re-do it, but it'll do for now.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 04-06-2007, 06:40 AM   #9
lewster's Avatar
Fan/Mate
KJ,
Good choice if you have the fans in already. I put these on my past MoHo and they worked great in inclement weather. I was going to go that route on my CCD, but decided to change out the Fantastic for the MaxxFans. Works great either way!
Install is easy, just follow the well written directions. One thing they don't mention but I always do when installing these is to add sealant OVER the mounting bolts for the brackets that you place THRU the existing fan walls. Even though they are protected by the cover, you never know when you'll be in a driving rain storm and why leave the possibility of seepage there. I usually overbuild and seal anyway!!!
Old 04-14-2007, 08:00 PM   #10
McKinney , Texas
Fan Mate 900 does not fit the actual fan in the rear of my 2007 Safari 27' front bedroom. The radio antenna gets in the way. It works great on the front vent. I will have to get a different cover for the rear fan.
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
Canadian Model Airstream? 53flyingcloud Our Community 5 11-29-2002 05:00 AM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
