Old 05-04-2008, 03:48 AM   #1
thripplewood's Avatar
1998 25' Excella
manchester , UK
Maxair Fans Not Working
Hello all
Would like help and advice please. I have 2 Maxair extractor fans mounted in the ceiling of my 1998 Airstream in the UK.
After testing the fans I find they are working if I put a 12volt feed directly to the fans.
I have now arrived at the conclusion the there is a break or a fuse blown between the switch and the fans. However I am unable to trace the fault as the wiring leaves the switch and then into the inner skin eventualy making its way the to fans and also making it impossible to access the wiring.
Cannot find any obvious in line fuses that may have blown and now stuck for a solution.
Question, would Airstream have put in an line fuse somewhere between switch and fan, and if so why would it be put in a place thats inaccessable.
Any help appreciated.
regards thripplewood.
Just driving my Dodgem Car through life.
thripplewood is offline   Reply With Quote
Old 05-04-2008, 05:40 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You may have a blown fuse in the main panel. Do all the lights work?
Old 05-04-2008, 06:21 AM   #3
1994 30' Excella
Mississauga , Ontario
I assume you have checked that the switch is good.
Al
Old 05-04-2008, 07:05 AM   #4
richinny's Avatar
2011 34' Classic
there might be a fuse located just before the switch. where are the fans located? are they both in the same place?
Ricky
Old 05-04-2008, 07:29 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Thripplewood,
You can totally remove the MaxxFan from the roof (with the sealed mounting flange remaining in place) by removing the 2 screws on the side of the flange. You can then remove the inner shrouds and get to the wiring, fuses, etc.
Bench test it with a car battery and see what you find!
Old 05-05-2008, 01:31 AM   #6
1998 25' Excella
manchester , UK
Hello All
Good advice everyone thanks.
Everything else works, interior lights, step light, fantastic fan works.
Switch is good and tested.
The fans are located in the ceiling and are about three feet apart and run off the same electrical feed.
No visable fuse before the switch as I have traced the wire from switch to where it goes into the inner skin.
will have to try Lewsters suggestion of taking the fans out of the ceiling to access the wiring.
regards Thripplewood
Old 05-05-2008, 06:09 AM   #7
richinny's Avatar
2011 34' Classic
ok, you have a bad ground or a break in the power between the first fan and the power source. ok, i did the easy part ;-)
Ricky
How many fans? Argy 78 Roof Vents, Skylights & Fans 33 04-12-2008 10:05 PM
fans or no fans goransons Refrigerators 8 12-31-2007 12:21 PM
Hello Airstream Fans! Su-Z-Q Member Introductions 24 03-04-2007 04:37 PM
Are There Any NASCAR Fans Here davidh Off Topic Forum 47 04-03-2006 07:55 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
