Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 05-26-2010, 10:35 AM   #1
rogerdodger's Avatar
1974 Argosy 28
Fresno/Clovis , California
Kitchen hood vent leaks when it rains
Anyone know if the vent rubber gasket is replaceable? Where to buy it? Or, another way to fix the leak?
Thanks in advance.
I posted this in another place, got no answers. So, here is what I did. I removed the outside vent cover, removed the old gasket (6"round). Then I removed all the screws holding the vent in place, lifted the vent assembly, and put Vulcrum between the vent assembly and the airstream exterior, tighened screws. Then I put new gasket material using 5/16" thick 5/8 wide all around the opening. I then adjusted the closed vent so there is no daylight coming thru. It will rain later today, I will update on this fix.
Roger
rogerdodger is offline   Reply With Quote
Old 05-31-2020, 11:25 AM   #2
Rich W's Avatar
2006 23' Safari SE
I'm In , Kentucky
Old thread, but similar question
I took off my kitchen vent to repaint and there is some kind of insulation residue on the AS skin from the original adhesive. It looks like the stuff you put around windows in older homes for added insulation but it's much stronger. It hasn't been leaking so no problem there. Just wondering what would be a good replacement? I have some Gorilla Glue double sided sticky tape. Would that suffice? Alternative?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Kitchen hood vent leaks when it rains rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 05-20-2010 08:38 AM
New kitchen exhaust hood altamont Stoves, Ovens & Microwaves 0 01-23-2009 03:29 PM
1982 280 Leaks when it Rains k_rasmussen Classic Motorhomes 10 11-24-2006 07:04 PM
Kitchen Hood Exhaust Darryl Stoves, Ovens & Microwaves 1 10-15-2005 07:24 PM
Stove vent hood Rob30044 Roof Vents, Skylights & Fans 3 08-27-2005 02:24 PM
