Old 05-26-2010, 10:35 AM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Kitchen hood vent leaks when it rains
Anyone know if the vent rubber gasket is replaceable? Where to buy it? Or, another way to fix the leak?
Thanks in advance.
I posted this in another place, got no answers. So, here is what I did. I removed the outside vent cover, removed the old gasket (6"round). Then I removed all the screws holding the vent in place, lifted the vent assembly, and put Vulcrum between the vent assembly and the airstream exterior, tighened screws. Then I put new gasket material using 5/16" thick 5/8 wide all around the opening. I then adjusted the closed vent so there is no daylight coming thru. It will rain later today, I will update on this fix.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Kitchen hood vent leaks when it rains rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 05-20-2010 08:38 AM
New kitchen exhaust hood altamont Stoves, Ovens & Microwaves 0 01-23-2009 03:29 PM
1982 280 Leaks when it Rains k_rasmussen Classic Motorhomes 10 11-24-2006 07:04 PM
Kitchen Hood Exhaust Darryl Stoves, Ovens & Microwaves 1 10-15-2005 07:24 PM
Stove vent hood Rob30044 Roof Vents, Skylights & Fans 3 08-27-2005 02:24 PM
