08-20-2018, 02:46 PM
Hammond
, Wisconsin
Installing Maxxfan's in a '79 Question
We just purchased two Maxxfan deluxe's for our 1979 31' Sovereign. My question is did you install it with butyl tape and sealant or just sealant. I know I will have to square off the corners of the original opening. I just was wondering what you guys have used and that it worked. The debate on this forum on sealant is making me start to twitch. I just want to use what works well and holds up the longest.
08-20-2018, 07:45 PM
1976 31' Sovereign
2000 33' Land Yacht
Ball Ground
, Georgia
Sealant
I installed two Maxxair delux in a 1969 Sovereign this weekend and three in my other 1976 several months ago. Both I used Butal tape. The last one I also ran a bead of sealer around the inside so when placed it , the sealant made a nice bead. The other I ran a bead once installed. I think applying sealant before installing made a better looking job. Spend the time so you don’t have a leak so you can forget about it.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
08-20-2018, 08:09 PM
Hammond
, Wisconsin
GAT thanks for the response. What sealant did you use?
08-20-2018, 08:15 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I’ve installed them in my ‘07 and my ‘14. Butyl tape and self leveling sealant.
2019 Ford Expedition Platinum
08-20-2018, 08:16 PM
Cuddebackville
, New York
I used Dicor because I could get it readily. It’s holding up just fine.
08-20-2018, 08:31 PM
Hammond
, Wisconsin
Thanks for the response guys! I will be installing them this weekend.
08-20-2018, 09:54 PM
1975 Argosy 28
Springville
, Alabama
I used sikaflex 721 above and below the flange. No issues
Matt
08-21-2018, 11:43 AM
Sevierville
, Tennessee
Thinking about doing the same thing in the same year/model. Thanks
08-21-2018, 07:35 PM
1974 27' Overlander
Baltimore
, Maryland
I like butyl tape under the lip because it's removable. Urethane sealant is a heck of a strong glue, and semi-permanently gluing the frame to your roof is going to be a maintenance nightmare when you need to remove it to fix something down the road. Best to do butyl tape under the lip and urethane sealant of your choice around the edge to seal (sikaflex, dicor, whatever).
08-21-2018, 07:39 PM
1975 Argosy 28
Springville
, Alabama
I totally agree with this. Wish I had done mine this way. I got in the zone of only polyurethane caulk is all you need.
Matt
09-05-2018, 07:16 PM
Hammond
, Wisconsin
Olympic Rivet or screws provided?
If the weather holds out on Friday I will be installing both MaxxFans. What did you use to fasten them down? Olympic Rivets or the screws provided?
09-08-2018, 07:48 AM
1974 27' Overlander
Baltimore
, Maryland
We used stainless screws. Butyl tape under the lip of the frame, urethane sealant on the screw threads before screwing in, then urethane sealant around the perimeter and over top of each screw.
https://thegreatleys.com/journal/201...-roof-supports
09-10-2018, 03:45 PM
Hammond
, Wisconsin
Thanks that is what I was planning. Glad to hear that I was heading in the right direction.
