Old 07-18-2016, 02:37 PM   #1
Sdt
2004 25' Safari
Blue Mountain , Mississippi
Installing a Fan-Tastic vent roof
Thinking about installing a Fantastic fan in my roof vent on a 04 Safari 25'. Any helpful ideas as to finding some wiring to tie into and type of sealant. The fan says 14 1/4 X 14 1/4" opening and I assume that is standard on my AS ?
Sdt is offline   Reply With Quote
Old 07-18-2016, 02:41 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Can't help with the wire location, but you may want to consider a MaxxAir fan instead. It several advantages, the biggest being that it can operate in the rain. Uses the same size opening.
When I changed out my fans, I seated it on a bed of butyl tape, then used self-leveling sealant over the screws and seams. Never had a problem.
2012 Dodge Durango Hemi/AWD
Old 07-18-2016, 02:51 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The fans in my Safari are both tied into the adjacent ceiling light for their power source. That is the easiest location to access.
The only negative is that both the light and fan are controlled by the switch on the wall. So, those wall switches are left in the on position continuously and the switch on the fan and the switch on the light are used exclusively to control these fixtures.
Add edit: you will have to enlarge the existing fan opening and add some framing around the perimeter of the opening. It is a fairly easy project.
Alan
Old 07-18-2016, 03:05 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I just replaced mine. I used butyl tape between the fan flange and roof and Dicor on the screw heads and along the edge where the flange meets the roof.
CRH is offline   Reply With Quote
Old 07-18-2016, 04:10 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Don't use the counter sunk screws that come with the FF. It is very easy to get them too tight and the flange will crack. Instead get some stainless steel pan head screws of the proper size and SS washers to put under the screw head. This will spread the pressure over a much larger area and greatly reduce the chance of cracking the flange. I just used Vulkem and not the foam gasket that came with the FF. 6 years and not leaks or cracks.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-18-2016, 10:03 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I just bought mine....it did not come with a foam gasket.
Old 07-18-2016, 11:00 PM   #7
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I went with 2 MaxxAir Deluxe fans with remote control. 9 speeds with built in rain shield !
I also discovered that the Dometic A/C blows to the sides and rear like gang busters and just barely to the front because of the return air duct. Our living area is in the front so this
didn't work.
I replaced the Dometic with a Coleman Mach 8 That blows front to rear and is quieter.
ID:	267228   Click image for larger version
ID:	267230   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 07-19-2016, 06:58 AM   #8
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
+1 on the Maxxair ! Also, be prepared to enlarge the existing opening... (Inner AND outer skins may have to be cut to a larger opening) (( why isn't Airstream using a fan with a standard size opening? ))
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 07-19-2016, 11:11 AM   #9
Native143's Avatar
2013 20' Flying Cloud
Dunedin , Florida
I am so glad to read this. The Dometic A/C is useless to the front, been trying to figure out how to redirect the air to the front. They can't have a better design? I have 2014 Bambi so the problem still exists. Not ready to buy a new A/C so any ideas on remedies??? Thanks.
didn't work.
I replaced the Dometic with a Coleman Mach 8 That blows front to rear and is quieter.[/QUOTE]
"I'd rather rust out than wear out"
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 07-19-2016, 11:14 AM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
My Dometic blows front and rear.
Old 07-19-2016, 11:22 AM   #11
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
I had my standard 14"x 14" cheap vent in the bedroom of my 2007 25' Safari FB with a Fantastic Fan. The mechanic installing the fan spliced into the 12 v power supply to the Ventline fan installed in the ceiling of the shower.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 07-19-2016, 12:27 PM   #12
2006 25' Safari SS SE
LINCOLN , Nebraska
Fantastic Fan
I agree with Alan Warn; I have a 2006 Safari. The Airstream factory told me there should be pre-installed wiring in the ceiling near the opening to tie into for the fan. NOT!! I had to tie into the ceiling light that is controlled by the entry switch at the door. Works fine but you have to remember to not leave the entry switch in the off position.
MissingLink5 is offline   Reply With Quote
Old 07-19-2016, 01:17 PM   #13
turnerstream's Avatar
2005 25' Classic
New Braunfels , Texas
I've been planning on this upgrade too. Good tips here - Thanks!
turnerstream is offline   Reply With Quote
Old 07-19-2016, 01:25 PM   #14
Wayne&Sam's Avatar
Images: 21
On my 2007 and my 2014, the FF opening was exactly the same for the MaxxAir.
Fan-Tastic vent fan cover C FORD Roof 11 12-09-2015 12:47 PM
Fan-tastic a good replacement for a vintage fan vent? Globie64 Roof 1 08-23-2015 06:04 AM
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
